increasing octane? #1381120
02/03/13 09:03 PM
02/03/13 09:03 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hello, if i am running lets say 93 octane, how could i raise octane to 95 or 97? Moroso octane boost? E-85? Other? and if have 5 gal of 93 how much would i add?
Re: increasing octane? [Re: Dakota_Don] #1381121
02/03/13 09:40 PM
02/03/13 09:40 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
If you have a MP Engines book around there should be a good section on how little "octane boosters" actually do. I've always heard gas stations get their midgrade gas, by pulling from the lower and higher grade gas tanks. Don't know that for sure, but if so you could probably find a place that sells high octane race gas and buy a couple of gallons to mix in with what you have.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: increasing octane? [Re: Michael Ecks] #1381122
02/03/13 09:43 PM
02/03/13 09:43 PM
Alton, IL
Alton, IL
i did find this??http://www.ehow.com/how_7606189_use-isopropyl-alcohol-increase-octane.html
Re: increasing octane? [Re: Dakota_Don] #1381123
02/03/13 10:03 PM
02/03/13 10:03 PM
Alton, IL
Alton, IL
Re: increasing octane? [Re: Michael Ecks] #1381124
02/03/13 10:06 PM
02/03/13 10:06 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
... I've always heard gas stations get their midgrade gas, by pulling from the lower and higher grade gas tanks. Don't know that for sure, but if so you could probably find a place that sells high octane race gas and buy a couple of gallons to mix in with what you have.
That sounds like a big 'wives tale' story.
Gas is very regulated and monitored. No way of blending high and low octane at the pump.
Re: increasing octane? [Re: Dakota_Don] #1381125
02/03/13 10:10 PM
02/03/13 10:10 PM
Alton, IL
Alton, IL
Re: increasing octane? [Re: autoxcuda] #1381126
02/03/13 10:12 PM
02/03/13 10:12 PM
Kirkland, Washington
Pacnorthcuda Offline
Incorrect. Mixing the two is exactly how mid-grade is concocted.
Re: increasing octane? [Re: Dakota_Don] #1381127
02/03/13 10:13 PM
02/03/13 10:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
and this http://www.ehow.com/how_7990457_boost-octane-alcohol.html
Careful with that Ehow stuff.
Those instructions are sort of convoluted. Sound chopped up from some other info by a writer. At least, that article says to add a drying additive IF you use alcohol. Well alcohol IS a drying additive.
Re: increasing octane? [Re: Dakota_Don] #1381128
02/03/13 10:24 PM
02/03/13 10:24 PM
IN
ahy Offline
ahy  Offline
IN
Mixing in E85 will increase octane but reduce energy value. If you are running a carb, that means bigger jets to put more fuel in. Without the bigger jets, it will be lean and may make detonation worse. Once the tuneup was dialed in for a certain mix, you would have to be consistent from tank to tank which is hard.
Mixing race gas is a proven way to boost octane. Or convert to E85 with a dedicated alcohol carb and tune.
Re: increasing octane? [Re: Pacnorthcuda] #1381129
02/03/13 10:25 PM
02/03/13 10:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are you saying it's concocted/blended right at/in the gas pump at the gas station itself?
Or before it's delivered to the station?
Re: increasing octane? [Re: autoxcuda] #1381130
02/03/13 10:30 PM
02/03/13 10:30 PM
The pump blends it.
Re: increasing octane? [Re: Pacnorthcuda] #1381131
02/03/13 10:31 PM
02/03/13 10:31 PM
Columbus, GA
Columbus, GA
Wki - Qasoline Blending
Re: increasing octane? [Re: autoxcuda] #1381132
02/03/13 10:38 PM
02/03/13 10:38 PM
Columbus, GA
Columbus, GA
Checked out that article. And it looks iffy to me. According to my MP book, the three types of boosters contain either Alcohol (methanol), Aromatic Hyrdocarbons (Toluene), or Metallics (Lead of Manganese) with the first two being the least effective. If you can find a booster that actually contains tetraethyl-lead anymore (my book is quite old) you could go up 1.5 to 2 octane points. .75 points with the other two.
And I'm pretty sure isopropyl alcohol does nothing at all when mixed with gasoline. Tried it once in my younger days when I was having a pinging problem and it didn't help at all.
If no one around you sells race gas, call your airport and tell them you are working on an old cesna engine and see if you can buy aviation gas a gas can at a time. Heard of it being done back in the day, but not sure what fuel tax/legalities this would involve.
Re: increasing octane? [Re: Michael Ecks] #1381133
02/03/13 10:38 PM
02/03/13 10:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if i remember correctly, alcohol has no octane value. its just a slower burning fuel without a lot of BTU value. you need to research what "octane" is.
Re: increasing octane? [Re: Dakota_Don] #1381134
02/04/13 12:36 AM
02/04/13 12:36 AM
Alton, IL
Alton, IL
so basically all that stuff is hog wash............... but if i get 114 proof fuel(airplane) and add 1 gal of that to 5 gallon of 93 octane what would i have? Is there a chart? I cant find one at all.
Re: increasing octane? [Re: Dakota_Don] #1381135
02/04/13 12:41 AM
02/04/13 12:41 AM
RSNOMO Online rolleyes
Moparts Torchbearer
RSNOMO  Online Rolleyes
Moparts Torchbearer
Re: increasing octane? [Re: autoxcuda] #1381136
02/04/13 12:43 AM
02/04/13 12:43 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
That's how Sunoco stations did it back it the days of Sunoco 260. You had a 8 choices of octane from 190 to 260 just by setting the pumps handles.
Re: increasing octane? [Re: Dakota_Don] #1381137
02/04/13 12:46 AM
02/04/13 12:46 AM
IN
ahy Offline
ahy  Offline
IN
1 gallon of race 114 mixed with 5 gallons of pump 93 would give 96.5 octane based on straight ratios. It doesn't quite work that way but that gives you an idea.
If the race fuel is leaded, it will likely bring up the octane more than the straight ratio calculation. 97?, 98? it depends on the particular make-up of the two fuels. You may have to experiment to find the right mix for your combo.
Re: increasing octane? [Re: Dakota_Don] #1381138
02/04/13 12:50 AM
02/04/13 12:50 AM
Alton, IL
Alton, IL
Re: increasing octane? [Re: Dakota_Don] #1381139
02/04/13 01:43 AM
02/04/13 01:43 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I usually mix 5 gallons of Sunoco 110 leaded race gas in with whatever amount of Sunoco non-ethanol 93 to fill my tank and my car runs perfectly.
