Aluminum BB water pump housing comparisons? #1380349
02/02/13 01:19 PM
02/02/13 01:19 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
I am thinking of getting an aluminum big block water pump housing.
It looks like there are 3 options:
Mopar for $180 at Summit,
Sumit's house brand for $145, and
440Source for $65.
Needless to say, there is a pretty big price difference between these water pump housings.
I remember a few years back that people were having trouble with the 440Source housings because the passages were too small. Is that still the case or did they fix the problem? What about Summit's house brand? Or is this another case where I need to buy original and just take the punishment to my wallet?
Re: Aluminum BB water pump housing comparisons? [Re: Chilort] #1380350
02/02/13 01:25 PM
02/02/13 01:25 PM
tucson az
frank Offline
frank  Offline
tucson az
The 440 source housing water temp probe location is on the drivers side of the housing (at least mine is) May be an issue with stock wire harness. Maybe new housings have location on passenger side??
Re: Aluminum BB water pump housing comparisons? [Re: Chilort] #1380351
02/02/13 01:28 PM
02/02/13 01:28 PM
Kirkland, Washington
Pacnorthcuda Offline
I use a source housing. The issue comes down to using a good water pump whose impeller comes CLOSE to the housing but still clearances. And spin the pump at the right speed (right pulley diameters). Don't buy sources pump with the cast impeller...it's garbage IMO
If the rest of the system is up to par, radiator,fan,shroud etc, you'll be fine
Re: Aluminum BB water pump housing comparisons? [Re: Pacnorthcuda] #1380352
02/02/13 01:36 PM
02/02/13 01:36 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I am using both a Milodon high flow pump and high flow t-stat. I use stock '68 pulleys.
I have seen the threads on checking the clearance. I will do that when I put this thing together again for sure!
Re: Aluminum BB water pump housing comparisons? [Re: Chilort] #1380353
02/02/13 01:46 PM
02/02/13 01:46 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Has anyone gone to work with their sanding roles to open up the 440Source housing? Time is money though.
Re: Aluminum BB water pump housing comparisons? [Re: Chilort] #1380354
02/02/13 02:18 PM
02/02/13 02:18 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
Watch the E-Bag, I was able to pick up a new Mopar housing for 100.00.
Re: Aluminum BB water pump housing comparisons? [Re: fuseable] #1380355
02/02/13 04:57 PM
02/02/13 04:57 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I found a mopar pump and housing on the bag for $186. There are deals if you are patient.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Aluminum BB water pump housing comparisons? [Re: frank] #1380356
02/02/13 06:50 PM
02/02/13 06:50 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Me too on the temp sender. You'll have to splice wire in to make it longer.
Re: Aluminum BB water pump housing comparisons? [Re: DANA60] #1380357
02/02/13 07:38 PM
02/02/13 07:38 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Or simply drill and tap the housing on the passenger side.
Re: Aluminum BB water pump housing comparisons? [Re: BSB67] #1380358
02/02/13 07:45 PM
02/02/13 07:45 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
I have the mancini pump and housing on my 440 and so far so good.
http://chucker54.stores.yahoo.net/mabhealwapu1.html
Also reasonably priced
Re: Aluminum BB water pump housing comparisons? [Re: BEINGmeISaCRIME] #1380359
02/02/13 07:51 PM
02/02/13 07:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I got the whole package they sell with the pump and it all works EXCEPT the leaky chrome water neck
Gus
64 Plymouth Savoy
Dana 60
Re: Aluminum BB water pump housing comparisons? [Re: fourgearsavoy] #1380360
02/02/13 08:34 PM
02/02/13 08:34 PM
Kansas
Kansas
Gus
I got the same package, on my engine I've only had dyno time but the chrome thermostat housing hasn't leaked *yet* I prolly also shouldn't say chrome since I have since elminated the chrome and painted it hemi orange.
Re: Aluminum BB water pump housing comparisons? [Re: Pacnorthcuda] #1380361
02/02/13 09:26 PM
02/02/13 09:26 PM
I have a new pump with the "scroll" impeller with the curved blades & I think it has CAT cast into the body. Is that the bad one?
Re: Aluminum BB water pump housing comparisons? [Re: BEINGmeISaCRIME] #1380362
02/02/13 10:03 PM
02/02/13 10:03 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Gus
That chrome one is a junker and will leak..
Go to Napa ask for #BK 6051051, its like $6 is cast like the OE one...
Just my $0.02...
Re: Aluminum BB water pump housing comparisons? [Re: RapidRobert] #1380363
02/02/13 10:04 PM
02/02/13 10:04 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Dump those and get the one from Mancini...
Just my $0.02...
Re: Aluminum BB water pump housing comparisons? [Re: Sinitro] #1380364
02/02/13 10:18 PM
02/02/13 10:18 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Some information I just received from off the board suggests the CAT housing and 440Source housing are similar. I've never held them in my hands so I will admit I am going by hearsay.
I have also been told the Mancini part, which I had forgotten about, is good. That price looks great too.
Both the CAT and 440Source housings can be opened up.
Re: Aluminum BB water pump housing comparisons? [Re: Sinitro] #1380365
02/03/13 12:15 AM
02/03/13 12:15 AM
Kansas
Kansas
Gus
Just my $0.02...
OR I could always go this route
http://chucker54.stores.yahoo.net/mabialwane.html
Re: Aluminum BB water pump housing comparisons? [Re: BEINGmeISaCRIME] #1380366
02/03/13 12:22 AM
02/03/13 12:22 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I used the chrome neck from Mopar before. I have one word: junk.
Anything but that POS is an improvement.
Re: Aluminum BB water pump housing comparisons? [Re: Chilort] #1380367
02/03/13 12:48 AM
02/03/13 12:48 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I bought the 440 Source aluminum housing and pump years ago , never had a problem with over heating, bolted on with no problems. Use a after market gage so I don't know about the sensor location problem if there really is one.
Re: Aluminum BB water pump housing comparisons? [Re: fourgearsavoy] #1380368
02/03/13 01:49 AM
02/03/13 01:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Gus
Same hear as Mancini told me it was their parts but it looks just like the MP without the MP emblem on it. And yes the chrome thermo housing leaked and is junk. I just used my old housing as I painted it all Max Wedge orange. Ron
