Re: Big block and O/D auto trans
[Re: Cuda367]
#1380292
02/02/13 02:35 PM
02/02/13 02:35 PM
Posts: 2,905 Pattison Texas
CSK
Pattison Texas
jw bell housing,95 back a518 non electronic, out of dodge truck & cross member fabrication,shorten driveshaft,i converted to cable shifter. https://www.google.com/url?q=http://boar...Q9_70KSQsPzQqdQ
[Re: 76dodgeboy]
#1380294
02/02/13 06:50 PM
02/02/13 06:50 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I chose to use a diesel 518 non-lockup because I had one handy. But you can also use the lockup 518 as well.
To control the OD and lockup it uses a set of pressure switches that T into the governor port on the transmission. And then a vacuum switch that allows the transmission to drop out of OD or lockup when the need arises.
Much better than just wiring into toggle switches and flipping on and off all the time.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1380295
02/02/13 11:00 PM
02/02/13 11:00 PM
Posts: 5,967 British Columbia
chrisf
British Columbia
what mods did you use with the diesel trans?
[Re: chrisf]
#1380296
02/02/13 11:24 PM
02/02/13 11:24 PM
hp383
State of Confusion
I had to add a gas motor governor. I also added a nice valve body kit and used a quality rebuild kit. You can also use a V10 trans and it will already have the correct governor. I liked the idea of using the diesel/V10 518 since they are built to handle lots of torque I'm confident the power the 440 will put to it won't be an issue if I decide to have some playtime. Its also got a diesel D70 rear and a "new" military surplus D44HD up front. And I had custom rear driveshaft with 1410 u-joints made.
