Valve cover gasket leak #1379789
02/01/13 01:19 PM
02/01/13 01:19 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
I have recently installed the Mopar Performance black and aluminum valve covers on my 440 and they are leaking oil. The shop has asked me to provide the metal reinforced rubber gaskets but I have been reading many contridictory things about what gaskets work and which don't for these covers. What is YOUR real hands on experience for no leaks with these covers?
Re: Valve cover gasket leak [Re: 696pack] #1379790
02/01/13 01:44 PM
02/01/13 01:44 PM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
What has worked for me consistently is removing the valve covers, clean the mating surfaces on the engine and covers with lacquer thinner and let dry.
Clean them again with lacquer thinner and wipe with a clean paper towel,let dry.
Purchase new cork valve cover gaskets (not rubber)
and apply hi temp silicone on the valve covers in a small bead line in the center of the gasket area.
Place the new gaskets in the cover & make sure the gasket "tabs" lay in the valve cover tabs as well.(If you have covers that do not have locating tabs in the cover,then trim off the gasket to match).
After you lay the gasket into the bead of hi temp, Carefully turn the cover over and lay down on a table or work bench. I add some weight to the top of the covers so the gasket is compressed in the hi temp and let dry overnight.
After the covers and gaskets have set over night, apply hi temp silicone or Permatex soft set to the engine cylinder head mating surface. Take the valve covers and install on each side of the engine one at a time cross torquing the bolts for each side. Let them dry overnight.
The next day, start your engine up and enjoy leak proof valve covers. Works for me every time.
HR 20
Re: Valve cover gasket leak [Re: HotRod20] #1379791
02/01/13 02:28 PM
02/01/13 02:28 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
That's fine if you have a non adjustable valvetrain. I go in my V/Cs a handful of times a year to check my lash.
I like to use rtv to glue the gaskets to the V/C only. Then they come off the motor clean and when they need replacement (I also like the rubber ones) the cleanup happens only on the bench- no rubber crumbs fall into the motor.
Side note- I had a set of cast covers on a smallblock that would leak but only when I drove- not at idle. Turns out my air-gap's raised runners were barely hitting the inside edges of the covers and looking good but not quite compressing the gasket. I had to relieve (grind!) them a little to clear the runners so they would sit all the way down.
Re: Valve cover gasket leak [Re: 696pack] #1379792
02/01/13 02:52 PM
02/01/13 02:52 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I thought I always heard those valve covers sucked and leaked pretty bad??
Re: Valve cover gasket leak [Re: 68KillerBee] #1379793
02/01/13 03:04 PM
02/01/13 03:04 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the fel-pro 1610 blue stripe cork gasket is my favorite. silicone it to the valve cover and lightly lube it where it mates to the head for easy removal.
Re: Valve cover gasket leak [Re: lewtot184] #1379794
02/01/13 03:43 PM
02/01/13 03:43 PM
MA
1968 Charger B5 Offline
MA
1. If you are running an edie rpm intake or other tall intake, check the intake side of the valve cover and make sure it is not contacting the intake, I had to 'tickle' the mp black valve cover on my 360 to fit with a tall intake I was running.
2. I have run both the felpro cork gasket and the rubberized metal gasket. I prefer the latter. Although, honestly I have both work fine.
3. Clean the surfaces well, do not over rtv, and check to make sure there is no other interferences with the valve cover, or also a tiny pcv leak that runs down and looks like a vc leak...
Good luck
1968 Dodge Charger R/T
1971 Plymouth Roadrunner
1998 Jeep Cherokee
Re: Valve cover gasket leak [Re: 1968 Charger B5] #1379795
02/01/13 05:40 PM
02/01/13 05:40 PM
Minnesota
Shawnb Offline
Shawnb  Offline
Minnesota
I had these black wrinkle Mopar valve covers on my 68 Bee. They always leakes. Most at the rear of the left head. THe best success I had was clean all off with brake clean and use the "right stuff" rtv on both sides of new rubber gaskets. Still was not 100% gone so I went to the aluminum 440 Source ones. They work great. I would ditch the Mopar ones.
Re: Valve cover gasket leak [Re: 696pack] #1379796
02/01/13 08:05 PM
02/01/13 08:05 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
I've got MP black wrinkle aluminum valve covers on my 340 and am using the MP steel reinforced rubber gaskets with no sealant.
They've been on the engine for three years and haven't even tried to leak.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Valve cover gasket leak [Re: 340727dart] #1379797
02/02/13 03:45 AM
02/02/13 03:45 AM
anacortes,wa
78asprin Offline
78asprin  Offline
anacortes,wa
I run my black mp cast vc's with 2 gaskets, one siliconed to the vc and one to the heads, I run studs with nuts, since I have to adjust my rockers with the roller rockers, there's no changing gaskets all the time, havent changed a gasket for the last 6 times ive had the vc off.
Re: Valve cover gasket leak [Re: 78asprin] #1379798
02/02/13 03:47 AM
02/02/13 03:47 AM
anacortes,wa
78asprin Offline
78asprin  Offline
anacortes,wa
Oh and no silicone between the 2 gaskets
Re: Valve cover gasket leak [Re: 78asprin] #1379799
02/02/13 07:36 AM
02/02/13 07:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had them on my 440 and now they are on my kids 413.We use Mr Gasket Ultra seals.I even had them off a few times to check my lash.Never a leak.I always install dry.RTV and cork dosent mix.It will turn cork to mush sooner or later.Rocky
Chrysler Firepower
Re: Valve cover gasket leak [Re: therocks] #1379800
02/02/13 11:40 AM
02/02/13 11:40 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
rtv and cork don't mix?.....
Re: Valve cover gasket leak [Re: lewtot184] #1379801
02/02/13 02:35 PM
02/02/13 02:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive seen too many cork gaskets turn to mush with RTV.Most people want to use it as a gob.Had one car come in with new FelPro gaskets.Pour oil in and it came out as fast as it went in.Pulled the covers and the RTV had made them almost like a liquid gasket.New set and dry and all was good.Never could understand why people pay good $$$$ for gaskets then goob them up with RTV.Mine all go on dry.No leaks.Only thing I will use on some is 3M adhesive to glue them to the part.Lots of new stuff you arent going to get the gasket in place unless its stuck to the part you are installing.Only time I use gasket sealer is on stat housings and some water pumps.then I use Permatix brown.Been doing that everyday for 30 years as a tech.Rocky
Chrysler Firepower
Re: Valve cover gasket leak [Re: therocks] #1379802
02/02/13 03:43 PM
02/02/13 03:43 PM
Amherst,NY
challengermike Offline
Amherst,NY
I agree, i see alot of people trying to seal cork or rubber trans pan gaskets with rtv and 90 percent of the time there leaking. I always use cork gaskets dry and have not had a problem with them leaking.
Re: Valve cover gasket leak [Re: 696pack] #1379803
02/02/13 03:47 PM
02/02/13 03:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
Which heads are you running, stock or after market aluminum ones? If stock heads use the cork and rubber thick ones, don't over tighten them If your using aluminum haeds that have a machined flat surface for the gaskets to seal against, look real closely at the valve covers and the head sealing surfaces for small imperfections that the gaskets aren't sealing agianst IHTHs
Re: Valve cover gasket leak [Re: Cab_Burge] #1379804
02/02/13 04:13 PM
02/02/13 04:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Chrysler made how many millions of engines without RTV on the VC gaskets? Hmm, all of them I think.
I prefer the metal reinforced rubber gaskets myself. If they don't seal your problem isn't the gasket, it's something else. Others have mentioned that the MP cast aluminum VC's sometimes need fitting to seal properly. Sheetmtal VC's can get tweaked, especially when you are prying them off because some PO(S) RTV'd them on to "cure" a leak.
Don't be the exception.
Re: Valve cover gasket leak [Re: 696pack] #1379805
02/02/13 05:18 PM
02/02/13 05:18 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Hi-Temp' gasket between an 'as cast' cover, and a cast iron head...
Been in there over 10 years...
Dry...
No leaks...
Re: Valve cover gasket leak [Re: Supercuda] #1379806
02/03/13 07:07 AM
02/03/13 07:07 AM
alaska
69 mayflower Offline
alaska
I agree, never understood why you need to glob some kind of sealant on a gasket. . I use some gasket tack to hold it to the part while installing, then just be careful not to overtighten. Get em good and snug but not enough to deform the gasket. Works on both rubber and cork. I'm still a fan of good ole' cork.
1969 Plymouth Sport Satellite 383 1990 Dodge W150 plowtruck 318 2012 Dodge Ram 1500 4WD 5.7 HEMI 2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
