727 Transmission problems #1379549
01/31/13 10:45 PM
01/31/13 10:45 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Hey Guys,
a friend is having a problem with his 727
it has a cheetah full manual reverse valve body. when in first gear the trans seams to be slipping when he floors
it but when he drives it normal it acts fine. when he shifts at WOT from 1st (slipping) into 2nd the car will fry the tires?
2nd to 3rd is perfect tho. one of the local guys he knows said it has
something to do with a spring adjustment but wasn't very clear as if he really didn't know LOL..
He really hopes its a easy fix he don't want to pull the trans out & fluid don't smell burned.
any help for him would be great thanks
Re: 727 Transmission problems [Re: GTXbound] #1379550
02/01/13 02:00 AM
02/01/13 02:00 AM
it
at that time does the RPM flare up noticeably? I'd wait for Kunkel to chime in so here's a BTT
Re: 727 Transmission problems [Re: GTXbound] #1379551
02/01/13 02:10 AM
02/01/13 02:10 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
When its acting like it slipping when he floors it is this from a dead stop, and just mashing the go pedal? Or is he torquing it up and then launching?
I wonder if it may be the converter flashing to its max stall if its just a full floor from a stop?
In my car if i didn't torque up against the converter before nailing it it would flash stall, and sort of seem like it was slipping. Not sure if his is the same problem.
So heres another
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 727 Transmission problems [Re: hp383] #1379552
02/01/13 05:03 AM
02/01/13 05:03 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
So heres another
thats what it sounds like to me, mine has a 3500 stall and if i floor it from a slow roll it takes a second to catch.
Re: 727 Transmission problems [Re: bonefish] #1379553
02/01/13 08:59 AM
02/01/13 08:59 AM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
well i dont think its the flash stall he is foot stalling it
up to about 2000rpm at the line its a little looser then a stock verter but it just isn't acting rite.
just thought its weird that it slipping in first as soon as he shifts to 2nd it will light the tires right up like he was neutral dropping haha.
Re: 727 Transmission problems [Re: GTXbound] #1379554
02/01/13 11:41 AM
02/01/13 11:41 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
He needs to be careful , if the valvebody doesn't have low band apply and it feels like it's slipping in first but is fine in other gears that sounds like the sprag is on it's way out to me ...
Re: 727 Transmission problems [Re: JohnRR] #1379555
02/01/13 01:41 PM
02/01/13 01:41 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Some cheetah valve bodies didn't have low band apply, most of the older ones didn't. As John said, beware the exploding drum.
Re: 727 Transmission problems [Re: GODSCOUNTRY340] #1379556
02/02/13 01:02 AM
02/02/13 01:02 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Very sound advice, also why you never start a burnout in 1st gear, always start in 2nd for the burnout, or ever get on the throttle-let off- and back on while in first gear with the non-band apply VB.
Also a good idea to either get the carbon fiber trans shield, or add 1/4" steel plate to the inside of the trans hump under the carpet. And upgrade to the billet steel drum.
This is what happens when the sprag goes away. The transmission spins at something like 10X its normal RPM's and things come apart, and get thrown, Toes, feet, etc. can be lost...
And another carnage incident...
Re: 727 Transmission problems [Re: hp383] #1379557
02/02/13 01:03 AM
02/02/13 01:03 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Pictures were referenced from this post:
https://board.moparts.org/ubbthreads/showflat.php?Number=5257020
Mucho more bueno info there!
Re: 727 Transmission problems [Re: hp383] #1379558
02/03/13 12:08 PM
02/03/13 12:08 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Hey Guys thanks for all the answers
i told him what everyone said and he agreed to
pull trans out and take it to trans shop to check it out.
what billet drum do you guy use ?
i know he dont have a big budget to spend right now
but i think i can push him in to buying it based on safety.. thanks
