The other part of the equation is that most tapered rear wheel bearings are set with, or wear to the point, that they have a significant amount of endplay. The problem is that the rotor can now move axially by that amount, pushing the piston(s) back. This results in a disconcertingly low pedal on the next brake application.
Experience has proven, however, that the stock Timkens can be safely run with very little endplay (I run 0.003"), or even a skosh of preload, mitigating the problem entirely. So you can keep your Timkens, having your cake and eating it too!
Rick
