Don't worry you couldn't "hurt" the actuators pulling any vac, even 30".....don't apply compressed air though, vacumm only, if the actuators open but don't close, either look at the return lines on the actuators for leaks/cracks/disconnected lines,...next up is the white plastic slider vacumm switch that is mounted behind the headlite dash electrical switch, the rocker portion of the switch activates the white slider switch to cover or expose the required port(s) to open/close the headlites, to test the system, disconnect the vacumm bulkhead of the white slider switch, it just pushes on/off, the middle port on the vacumm harness is the constant vacumm supply from the reserv. canister under the battery tray, the top and bottom lines are the up/down activation, just apply vacummm from a hand activated Mityvac type, or steal vacumm from the actual car running, or another donor source of vacumm, if you can activate the headlite doors up and down, and hold them in the desired position, then change out the slider switch, repros are available, used switches usually suffer the same problems...
Mike
