400cid motor #1379282
01/31/13 08:25 AM
01/31/13 08:25 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Hi
Did anyone used CCA-CL21-223-4 or similar camshaft on a 400cid about 9,5-10CR ratio motor before? Cilinder heads are stock, dual plane intake and headers.
Your comments?
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: 400cid motor [Re: Georg] #1379283
01/31/13 10:49 AM
01/31/13 10:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://www.summitracing.com/parts/cca-cl21-223-4
fairly mild cam should work good!
Re: 400cid motor [Re: Dodgem] #1379284
02/01/13 04:01 PM
02/01/13 04:01 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Trust me here...I knows a little
Crower 271hdp 222/234@.050 .496/.486 cut it on 108 LDA and put it in +3 at 105 ICL
This is an awesome 383-400 cam.....talk the talk and walk the walk
WIZE
In Car:
Re: 400cid motor [Re: Streetwize] #1379285
02/01/13 05:57 PM
02/01/13 05:57 PM
dogdays Offline
dogdays  Offline
With a cam you pay once and live with the results. Spending a few $$$ more to get a better cam is worthwhile. We have had other members with that same Crower cam in a 383/400 and they have loved it. Listen to Wize.
Summit cams don't light up my board.
R.
Re: 400cid motor [Re: dogdays] #1379286
02/01/13 07:59 PM
02/01/13 07:59 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
In my early 1972 400 I used a 292-509 purpleshaft, and it was a real good runner.
It had the std. bottom and std. 906 heads with a Holley street dominator and a early Thermoquad.
It was one of my best street engines ever.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: 400cid motor [Re: MrSixpack] #1379287
02/01/13 08:24 PM
02/01/13 08:24 PM
ON, Canada
AMC400Mopar Offline
AMC400Mopar  Offline
ON, Canada
This might be a dumb question, but when installing a cam in a lower compression engine is it better to install it straight up, 4' advanced or 4' retarded? I would guess retarded would give a little more overrev and advanced would bump up the low end torque???
Re: 400cid motor [Re: AMC400Mopar] #1379288
02/01/13 08:46 PM
02/01/13 08:46 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
AMC,
For me it's more about knowing the head flow, the displacement and (primarily) where I want the intake valve to close. It's often better overall to put a slightly larger intake lobe in the motor and close it earlier, if you know how to 'get it right'it's a win-win, better overall power and no appreciable loss in low end torque.
When correctly chosen, Crower's mopar hydraulics flat out work, better torque and power on both sides of the powerband than the lobe @ .050 might lead one to believe.
As Dogdays said, I've suggested that cam on here for years, and other places both on 108 or 112 (depending on the app) and never heard nothing but great feedback on the choice. Nobody's run me off of here yet
WIZE
In Car:
Re: 400cid motor [Re: Streetwize] #1379289
02/02/13 01:02 AM
02/02/13 01:02 AM
Fort Collins, CO
justintyme Offline
justintyme  Offline
Fort Collins, CO
Sounds like a good cam to try. Just picked up a new to me 69 Roadrunner after being Mopar-less for a few years. Has a decent runing 383, 4 speed, 3.55 gears. Could use a bit more cam though, would you like the tight LSA for this application Streetwise? Spent too much on the car, gonna be a while till I can build a stroker for it and I dont know what the internals of this 383 are. Stock intake, air grabber, Stock exhaust manifolds. Will have to do a compression test soon to see how healthy it really is.
Re: 400cid motor [Re: justintyme] #1379290
02/02/13 08:41 PM
02/02/13 08:41 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Either one but the 108 would be torkier,...your car would benefit from a less restrictive intake up in Fort Collins the air is pretty thin.
WIZE
In Car:
Re: 400cid motor [Re: Streetwize] #1379291
02/02/13 08:50 PM
02/02/13 08:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
how would a 108 be torqier than 112 108 has more overlap than the 112 thus not torkier.
Re: 400cid motor [Re: CSK] #1379292
02/02/13 09:13 PM
02/02/13 09:13 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
108 gets up on the power faster than 112. I had a 112 lobe sep once and it was real lazy off the line. My 408 likes 108 way better.
Re: 400cid motor [Re: mopar dave] #1379293
02/02/13 09:42 PM
02/02/13 09:42 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
I have a old crane cam 504/528 cut on a 112 I plan to install at 106/108 in my 400
Re: 400cid motor [Re: CSK] #1379294
02/02/13 11:28 PM
02/02/13 11:28 PM
Fort Collins, CO
justintyme Offline
justintyme  Offline
Fort Collins, CO
Thanks for the suggestion, a new intake is part of the plan, figuring out which ones I can make work with the air grabber setup. I need to get another base and see how far I can drop it, possibly go with a performer, althought I would like an RPM, not sure if I can fit that. Maybe a dp4b edbelbrock if I can find one. Oh and Headers possibly too.
Re: 400cid motor [Re: justintyme] #1379295
02/04/13 06:56 PM
02/04/13 06:56 PM
IL
furious70 Offline
furious70  Offline
IL
FWIW a holley street dominator is low profile. It does give up low end tq but it does as well up top as anything else per the great intake comparo tests.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 400cid motor [Re: furious70] #1379296
02/05/13 12:28 AM
02/05/13 12:28 AM
Fort Collins, CO
justintyme Offline
justintyme  Offline
Fort Collins, CO
Thanks I'll keep an eye out for one of them also
Re: 400cid motor [Re: Streetwize] #1379297
02/05/13 10:02 AM
02/05/13 10:02 AM
maryland
74yellowduster Offline
maryland
i'm running a performer rpm cam for now because it came with my top end kit. the engine is ready, waiting in line for dyno. i will let you know how good or how poor it performs.
the specs to compare to the Crower above:
Edelbrock 7194 238/246@.050 .480/.495 In/Ex
LSA 110 C/L 105
my static comp ratio is 10.5:1
Re: 400cid motor [Re: 74yellowduster] #1379298
02/05/13 12:24 PM
02/05/13 12:24 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
That should also work well. FWIW...Edelbrock "re-brands" a lot of the old General Kinetics Hydraulic FT grinds from the late 60's and early 70's as their own. If you look at the old P.A.W. magazine ads, their S.S.I. (Super Stock Industries) "house/Econmy" cams are the same GK grinds that Edelbrock (and Summit) use.
WIZE
In Car:
Re: 400cid motor [Re: Streetwize] #1379299
02/05/13 12:28 PM
02/05/13 12:28 PM
maryland
maryland
i think it will be ok. i'm not a cam expert, but i think the eddie will have more bleed off, and reduce my compression more than the crower. so i will have less power, but less prone to detonate?
i at first figured i would have about 9.5:1 and told the machine shop not to mill the heads unless they had to. they had to lol and so my comp is 10.5. i'm crossing my fingers since i want to run super unleaded. maybe edelbrock does that on purpose, since the heads often need "adjustment" from what i have heard, buy putting a real bleeder in the package for a camshaft they kind of cover the mistakes lol
