Help me ID this part: 67 GTX or Belvedere TL lense? #1378890
01/30/13 11:10 PM
01/30/13 11:10 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Will this fit the 67 GTX style Tail Lamp or is it the more common Belvedere lense?
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378891
01/30/13 11:13 PM
01/30/13 11:13 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
pic
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378892
01/31/13 12:01 AM
01/31/13 12:01 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Belvedere. Wanna get rid of it?
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: moparguy7074] #1378893
01/31/13 12:10 AM
01/31/13 12:10 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
yep! pm me if you need it.
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378894
01/31/13 12:12 AM
01/31/13 12:12 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
its GTX isnt it???
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378895
01/31/13 12:48 AM
01/31/13 12:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If the lens has "RP" cast into it next to the number at the bottom it's 67 GTX/Satellite, if it's "RH" it's 67 Belvedere only. GTX versions are reproduced (nicely) so NOS values from days gone by are way down. Belvedere has not been reproduced and accordingly NOS values have remained solid
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: ScottSmith_Harms] #1378896
01/31/13 12:50 AM
01/31/13 12:50 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
it reads SAE STDB 67R
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378897
01/31/13 12:53 AM
01/31/13 12:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Is there a part# on that box?
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: ScottSmith_Harms] #1378898
01/31/13 02:10 AM
01/31/13 02:10 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Nope....isnt the pic big enough so an experienced person regarding 66 and 67 B Bodies can tell what it fits???
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378899
01/31/13 02:42 AM
01/31/13 02:42 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, but I can't see the pic up close as I'm currently viewing from my cell phone, I'll be at my computer in the morning and I'll chime in again when I can see it.
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378900
01/31/13 02:52 AM
01/31/13 02:52 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I think there's little extra notches on rearmost pointed part of lens when it fits gtx and satellite. That pic no got.
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: buildanother] #1378901
01/31/13 08:25 AM
01/31/13 08:25 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
That's a Belvedere lens. The easist way to tell them from a GTX/Satellite is that the GTX/Satellite version doesn't have the two horizontal ribs on the lens. Years ago when the supply of GTX/Satellite lens had been depleted but you could still get Belvedere lens, rather than grind the ribs off to eliminate the interference with the GTX/Satellite bezel, some bright individuals would instead cut the bars out of the bezel. I've got a couple sets of bezels that got that treatment which obviously ruins the bezel.
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: 6PakBee] #1378902
01/31/13 10:09 AM
01/31/13 10:09 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
awesome! thanks for the info!!!
Re: Help me ID this part: 67 GTX or Belvedere TL lense? [Re: domingo] #1378903
01/31/13 10:42 AM
01/31/13 10:42 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, I can see it now, yes I agree it's a 67 Belvedere for sure, I once bought a box full of those that came direct from the (long out of bussiness) manufacturer, they were never individually boxed and were probably blems that should have been scrapped because they had dark specs in them from a bad batch of material, they were easy to sell anyway as there were very few on the market. All the boxed ones I've ever seen had the yellow made in Canada sticker on them like yours does. Nice score!
