Hemi stroker combo - advice needed
#1378562
01/30/13 12:47 PM
01/30/13 12:47 PM
Posts: 1,262 Netherlands
72Challenger
Netherlands
Hi guys! Currently I'm in the planning / gathering stages of building a Hemi for the street so hydraulic cam, single carb, pumpgas etc. but as bigger is better I was wondering... Stock bore x stock stroke or maybe go for a 4.15 stroke or even 4.25 stroke? What combo crank / rod / piston would be needed for the 4.25 stroker? Off the shelf parts? Any pro's / con's / advice etc. is appreciated. At this moment I only have the block and heads besides some minor parts. Big thanks
Re: Hemi stroker combo - advice needed
[Re: 72Challenger]
#1378563
01/30/13 03:26 PM
01/30/13 03:26 PM
Posts: 2,688 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
At least a 472, depending on which block you have. Mainly off the shelf parts, so to speak. Don't need anything too fancy for that application. Just some cubic inches. Might be easier to get a rotating assembly from someone to fit your bore.
2011 Drag Pak Challenger
[Re: 72Challenger]
#1378564
01/30/13 03:36 PM
01/30/13 03:36 PM
Posts: 43,332 Bend,OR USA
Cab_Burge
I built a new motor for a local customer for his 1968 Charger R/T, not a original Hemi car,He wanted a new block so I bought a World block that was 4.190 rough bored at his insistence, I wanted to buy the 4.490 rough bore but he wanted stock bore size. I had it finished bored and hone with a torque plate to 4.25 and used a 4.25 stroke crank with BB Chevy rod journal sizes and a set of BB Chevy type forged steel 7.100 H beam rods and a semi custom set of Diamond low compression pistons,9.75 to 1 ratio, he wanted to use a set of used stock type Mopar iron heads off of a crate motor he had. I used a custom grind Comp Cams hydraulic roller lifter cam with there old noisy hydraulic roller lifters,(4 yrs ago) He is very happy with that combination, lots of torque He uses a set of 3.73 gears in his Dana 60 and a 28 or 29 inch tall tire, that combination flat moves that big heavy car, no enlightment done, big audio amp in the trunk along with a 34 gallon fuel cell He likes to drive that car in the good weather
[Re: Cab_Burge]
#1378565
01/30/13 03:41 PM
01/30/13 03:41 PM
Posts: 4,179 California
mickm
California
just depends where you want to go. to a point, building bigger inches doesn't cost anything more. stock stroke is 3.75. 4.15 crank will cost you the same (roughly) and get you 472 inches with the stock bore. now it is just up to you. what block you have, how far you want to take it.
my old motor is a 472, my new one is a 540, 4.25 stroke by 4.5 bore. i think in the end, the only real increase was the cost the machine work, (my block was a 4.19 bore, so taking it to 4.5 cost a few pennies more).
i haven't looked, but i don't think the cost of a stock stroke, 4.15 or 4.25 crank is that much different, if at all. rods are rods, and so are pistons, if you are ordering out of the catalog. custom is custom, and nothing here is too custom.
for a little or not much more, you can easily have a 540 over a 426.
[Re: Cab_Burge]
#1378566
01/30/13 06:20 PM
01/30/13 06:20 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Using a 4.25"bore you can get the following displacements; 4.15" crank 471 4.25" ..... 482 4.50" ..... 511 4.75" ..... 539 If the crank is available with a 2.2" rod journal use it, and if it's available with a chevy width journal all the better. Personally, I'd go with the largest displacement your wallet can stand. Dave
[Re: 72Challenger]
#1378567
01/30/13 08:52 PM
01/30/13 08:52 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Mine is a 4.31 bore x 4.25 stroke which is a 4.96. The only drawback of the small bore size so far is we had to machine an eyebrow at the top of the cylinder for the larger than stock 2.300 intake valve.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Brian Hafliger]
#1378571
01/31/13 01:29 AM
01/31/13 01:29 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
When I had mine built,I used a mega block with 4.390 bore and a 4.5 Bryant billet crank.The machinist suggested the 4.5 bore for a square 472 ci,I chose the smaller bore so i'd have room to grow when I hurt it next time.It's not "IF",,,,,,,,,it's "when"
[Re: hemi-itis]
#1378572
01/31/13 09:47 AM
01/31/13 09:47 AM
72Challenger
Netherlands
Thanks so far guys!
So what we know right now is...
it will be a stroker have and will use a 4.25 finished bored / honed block iron stock heads
So either a 4.15 stroke crank (Eagle 444241506760 ?) with 6.86 rods or 4.25 stroke crank (Eagle 444242507100 ?) with 7.10 chevy rods
When I check I see more then one chevy 7.100 rod, anybody any advice or part# ?
And what pistons to use with both combinations?
Still determining last bits so I can start gathering parts.
Thanks again!
[Re: dogdays]
#1378574
01/31/13 03:36 PM
01/31/13 03:36 PM
mickm
California
There is NO REASON to do less than a 4.25" stroke, unless you have a cubic inch limit in a racing class.
There is NO REASON to use anything other than a bigblock chevy style rod as they are the standard for most big motors. (Well, if you had a brand new set of Crowers in stock size on the shelf that'd be a reason.)
If you have all the money in the world I'd say get either Crower or Oliver or Carrillo. If you have a budget I'd suggest either K1 or 440Source or Scat, haven't checked them lately. For pistons you want shelf stock forged slugs that weigh the least, all Hemi pistons seem to be really heavy so even "lightweight" pistons will be heavy.
Put it all together and you'll have a super engine that will make unbelievable torque and love to rev. You should be able to knock 400 - 500 grams off the stock weight for each hole.
R.
lots of good off the shelf pistons these days. i think i marked it down somewhere, but my CP pistons weighed over 100 grams lighter than stock. i went with the 7.1 rods. got them from tim banning at FHO. many good sources out there to talk with, he is one of them.
[Re: mickm]
#1378575
01/31/13 04:16 PM
01/31/13 04:16 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Why not use a 4.5 stroke Molner forged crank and rods with the 2.2 journal size. Its the same money and another 30 cubic inches. The longer the stroke, the more torque available. If you have a world block, I used the external oiling to the front of the block using milodon road race pan 31581. I would NOT use a hydraulic roller, the valve train issues and clearancing are horrible. You can get a good Crane roller setup or Bullet cams and not have to do much grinding on the block and heads for clearnance. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
