best Head gasket choice - hemi #1377469
01/28/13 05:13 AM
01/28/13 05:13 AM
QLD Australia
Keith Black® Offline OP
QLD Australia
hi guys..
what is the best available head gasket choice for my app-
KB Hemi
4.31 bore
studs
Stage V heads
boosted but < 20 lbs, < 1500hp
regular driver.
looking for most reliable, lowest maintenance, etc.
your suggestions & experience greatly appreciated.
Darren Beale
Keith Black Racing Engines®
Re: best Head gasket choice - hemi [Re: Keith Black®] #1377470
01/28/13 11:59 AM
01/28/13 11:59 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
I had trouble keeping head gaskets on the hemi from seeping water. Switched to a cometic gasket and it fixed it. Cometics are pricey but i wouldn't run anything else on a hemi.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: best Head gasket choice - hemi [Re: HemiDart68] #1377471
01/28/13 12:02 PM
01/28/13 12:02 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Everybody is on the Cometic bandwagon. If your heads have steam holes and they are drilled for the KB pattern, get your head gaskets from KB. Normal ones will work.
2011 Drag Pak Challenger
Re: best Head gasket choice - hemi [Re: rickseeman] #1377472
01/28/13 12:24 PM
01/28/13 12:24 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My KB supplied head gaskets were Cometics.
Master, again and still
Re: best Head gasket choice - hemi [Re: DaveRS23] #1377473
01/28/13 02:45 PM
01/28/13 02:45 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am at the same bore size, 4.310" on my hemi and I had trouble with sealing last year using the stamped steel Mopar gaskets with the copper coat. Never was an issue before, but it was this year. Just switched to Cometics and decked the heads...Found the heads had a real slight .001-.002 twist end to end. If you know your block and heads are perfect, then the steel shim gaskets will work, anything else, Cometic...
Re: best Head gasket choice - hemi [Re: Keith Black®] #1377474
01/28/13 04:08 PM
01/28/13 04:08 PM
The KB blocks need a specific head gasket for each specific block, KB stage IV versus the earlier and later blocks can need a different head gasket. I ran into this problem when I was assembling a KB street block with dry sleeves, it has to have its own specific head gasket The sleeve hieght is critical on sealing the water passages up also Contact Ken Black at Kieth Black Ent. at 562-869-1518 to see which head gasket type you need
Re: best Head gasket choice - hemi [Re: Cab_Burge] #1377475
01/29/13 04:21 AM
01/29/13 04:21 AM
QLD Australia
QLD Australia
thanks guys I'll get KB to provide the head gaskets with the preference for cometics if possible
thanks again
Darren Beale
