Re: 440 Ring end gap orientation
[Re: MadMopars]
#1376455
01/26/13 10:09 PM
01/26/13 10:09 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
I've heard that they spin. My question is what reason do they have to spin and what is to say that each ring spins at the same rate. I know there have been several manufactures specify how they want the rings positioned at install so if they spin freely isn't it a lost cause? It sure is disappointing to think that all your ring gaps may line up at some point is it not?
Why would it matter if your top ring lined up exactly as your second, let alone one of your third ring gaps............. What would happen that is so bad??? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MadMopars]
#1376456
01/26/13 10:47 PM
01/26/13 10:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
In a shop manual it says to spread the gaps at 1/3 apart... to the guys that say they move around.... WHY do they move.... how come the ring gaps arent always lined up when you pull it apart ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1376457
01/26/13 11:40 PM
01/26/13 11:40 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Just statistically speaking, it would be rare to have the gaps lined up when you pull any one piston. Depending on resolution, there maybe 1/20 chance of them being "lined up" (to one's eye) and 19/20 that they aren't.
I don't know why they spin, but there seem to be so many forces and movements going on in there, and how they interact with the bore/hone etc., that it would be interesting to know why people think they don't spin.
[Re: Exit1965]
#1376458
01/26/13 11:51 PM
01/26/13 11:51 PM
MR_P_BODY
I dont know if they do spin... why is it you see some deep grooves(or ridges) in a bore... if they were spinning wouldnt the bore be smooth... I've pulled enough eninges apart and never seen the gaps lined up and if they do turn wouldnt the air thats passing through the gap try to line them up for the easiest path way out... I think once they seat they tend to stay there.... there is plenty of friction on both the wall and the piston to keep them stationary ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 10.90 Racer]
#1376459
01/27/13 12:24 AM
01/27/13 12:24 AM
Posts: 1,293 Tucson AZ,
MadMopars
Tucson AZ,
I do think blow by will take the path of least resistance and I'm not sure that I would risk putting a motor together with them all lined up. I am here to learn though. A few years ago we were making the 2nd ring gap smaller than the top. Times change huh? ![](/ubbthreads/images/graemlins/wink.gif)
[Re: 383man]
#1376461
01/27/13 12:52 AM
01/27/13 12:52 AM
MR_P_BODY
I have heard they spin but I cant say for sure. I do know I have pulled my engines apart and the rings were not the same as when I put it together. Thats why I put my comp rings 180 apart. If the comp rings were lined up would it make much difference ? I really dont think you would know. I mean I was always taught just dont line up the end gaps. Have them at least 90 degrees apart so I always install comp rings 180 apart and the oil ring gaps 180 away from the rail ends. Ron
I think they move during breakin then I think thats it.... this is JMO... because I dont know for fact if they do or dont move.... maybe some of the engine builders can explain ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Baxter61]
#1376463
01/27/13 01:22 AM
01/27/13 01:22 AM
MR_P_BODY
Theres an SAE paper you can purchase, $9.95 i think, that explains the use of radio tracers in tracking ring rotation. I havent read it in about 8 years so i dont remember all the specifics. I just remember reading the top ring spins faster than the 2nd ring, about 6 times faster if memory serves. I also dont remember how "broken in" the motor as and how many pulls they put on it to track this.
Ok.... now why do they turn... there is plenty of fiction happening in there.... or dont they really seal.... I'd like to know the WHY part... I've heard they turn(I still dont know for fact) but if they do then why ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Cab_Burge]
#1376466
01/27/13 07:16 PM
01/27/13 07:16 PM
10.90 Racer
super street
super street
Ont. Canada
They probally move when the piston is changing direction and that takes the preload off of the rings when the pistons stop and reverse direction I have taken motors apart that I staggered the rings in after breaking the in cam and lifters and 30+ dyno pulls, them dang rings weren't in the same positions as I installed them in :shrugg:I have seen some of the top and second rings aligned perfectly after dyno testing, some of the oil ring expanders close to being aligned but none of had all the rings aligned perfectly in one cylinder Life goes on OP, I stagger mine in thirds, no particular method as long as there is a stagger Normally I will align the oil rings over the wrist pin and have the second ring 120 degrees away from the top oil ring, have the ring gap on the top ring 240 degrees away from the second ring gap I think if the rings didn't move around we would see grooves worn into the cylinders from where the ring gaps stayed I haven't seen any block that way except in a rebuilt motor with a broken ring
![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: BigBlockMopar]
#1376468
01/28/13 06:45 PM
01/28/13 06:45 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Rings may or may not rotate based on a number of factors, but the most important one is the cylinder wall cross hatch angle and depth. if the cross hatch is at an improper angle, the rings may actually rotate rapidly, wearing out the rings and ring lands prematurely. Another problem with improper cross hatch angle is either too little or too much oil on the cylinder walls. The wrong angle can actually work like a pump and overwhelm the oil rings and scraper. Something else to keep in mind, if the engine was assembled with the ring gaps staggered, there probably would NOT be a line from the ring not rotating unless it was at the very top of the bore. How many have pulled an engine apart and found that there is indeed a scratch in the cylinder wall that goes straight up and down. That's quite common because of a burr on the ring end. clearly that ring didn't rotate orthe scratch would be circular in nature. food for thought att the very least. When your not sure where to place the gaps, i believe all of the manufactures sell their rings with instructions. if you can't find the correct answer there, just go to the total seal website and look it up. I know that'll take a few minutes extra time, but at least you'll get the correct answer from the guys that actually make and test those darn things. ![](/ubbthreads/images/graemlins/thumbs.gif)
machine shop owner and engine builder
