Re: Triple Black Bee
[Re: new bee]
#1376135
02/24/14 01:50 PM
02/24/14 01:50 PM
Posts: 5,268 NY
70440+6bbl
NY
Victory! Followed by defeat. Got it back together, running, and moving. Then the freeze plug on the drivers side rear of the head let go. Don't know if I'll be able to remove it and replace it without pulling the head or if I will have to yank the head. If I pull the head, I may pull both and get some work done. Hmmm...
It can be done as I did it on my Super Bee without removing the head. We used one of those long clamps often used in wood working. I'm not sure what they are properly called, but there is a hand crank on one end. In a nutshell, we adjusted the clamp to be roughly the width of the head. On the non-crank side, we replaced the end piece with a bolt. Next, we lined up the crank end with the front freeze plug, and the bolt with the back freeze plug. As we tightened up the crank, the bolt pivoted the rear freeze plug out. To install the new plug, we replaced the bolt with a flat washer the same diameter as the plug. Tightening the hand crank pressed the new plug in. Worked perfect.
Wow! That's a good one to remember
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#1376136
02/24/14 02:11 PM
02/24/14 02:11 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I thought the exact same thing!
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#1376137
02/24/14 08:18 PM
02/24/14 08:18 PM
Posts: 7,066 portland or
new bee
Richard Cranium
Richard Cranium
portland or
I wish I took a picture of it. You may have to do some of your own engineering as this tool we made has been gone for over 6 years.
*1969 383 4sp. Super Bee *1966 Alfa Romeo Giulia Sprint GT *1965 Porsche 356C *2004 VW Passat Wagon *2004 Mini Cooper S *1967 Jaguar E-Type FHC
A mall cop is in our midst.
[Re: new bee]
#1376138
02/24/14 10:42 PM
02/24/14 10:42 PM
OhioMopar
Mt.Gilead, Ohio
I'll figure something out to work. Knowing you did it and that I now have an idea of how, I'll get it done. Thanks again.
[Re: OhioMopar]
#1376153
03/17/14 07:45 PM
03/17/14 07:45 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
may be time to thin the heard and concentrate on one old car.I know my road runner and the wife's VW are enough for me.
1981 Dodge D150 360 auto
