I am using the Hughes Hydraulic rollers in my street 505" stroker. Basic 440 source 4.25" stroker kit with 7.1" rods, 17cc dished pistons, ported stealth heads (about 10.3:1 compression.) The cam is the Comp XR286HR-10, 236/242@0.050", and I'm running 1.7:1 rocker arms for 0.617"/0.614" lift.
Because of the higher lift, I decided to use the Isky 8005A valve springs, with Comp cams 748-16 retainers and 10-degree locks. The Isky spring is just a tad stiffer than the recommended Comp 925 springs. Isky spring rate is 400, Comp is 395, Isky seat pressure is 135, Comp is 111.
The engine revs pretty good and I have not noticed any valve float. I installed a Crane HI-6 with the rev limit set to 6,000, but I should bring that down to about 5,500?
I did notice more valve train noise on startup, but it seems to quiet down after startup, but the noise may be my cheap 1.7:1 rockers? I put a few hundred miles on the new engine last year, and I am planning to pull the valve covers to inspect the rockers and re-adjust them. I may also replace the stock steel valve covers with taller aluminum covers because my PCV valve is picking up some oil.
