Page 21 of 22 1 2 19 20 21 22
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: A12] #137522
05/11/09 06:58 PM
05/11/09 06:58 PM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
So are there deductions for non-correctness on reproduction parts
You get ZERO points in OE judging, for having a repo part. All “parts” are capable of receiving two point’s total. One point for originality and one point for the condition of the part. Since a repo is not original, it is automatically given a full one point deduction in that area. When you think about it, that is 50% of the total amount possible for any particular component. The part basically receives a failing grade before it is judged!
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137523
05/11/09 09:34 PM
05/11/09 09:34 PM
SE Pa.
LimeliteAero Offline
SE Pa.
After following this thread Im sure glad I dont participate in this level of showing.
I'm still amazed some of the parts that are uncovered are still being dug up. I'd have thought they were long gone.
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137524
05/11/09 11:05 PM
05/11/09 11:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Dave, thanks again for the reply and here's an original red cap to compare to your repo red cap. Remember I said that I could help I.D. an original battery from a reproduction early on in this thread and this cap with the five holes was one of the tell-tales, an older gentleman showed me this a while ago. There are a few other things but I know you and your team know what they are
MikeR
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: A12] #137525
05/11/09 11:07 PM
05/11/09 11:07 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
top side original, maybe it's the light but the originals seem brighter red IMO
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: sam c] #137526
05/12/09 10:52 AM
05/12/09 10:52 AM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
Hi Dave,I am currently getting ready to send my bumpers out for rechroming.I heard that you have obtained nos for the valiant.Could you post some pixs of the bumpers?I have been told that there are imperfections in original bumpers that are not duplicated after rechroming Thanks in advance.
Hello Sam! We did find all the "chrome" for this car in original NOS condition. You are correct about the finish. The originals appear to have a bit of an unfinished (scratched?) metal surface UNDER the chrome. I took some pictures of the rear bumper and one of the reverse lights we were able to locate. Dave Stuart has been responsible for finding about 75% of these parts. He is the Midwest District Zone Manager for Chrysler and has been able to locate original items from his data base that is linked with EVERY Chrysler outlet across the Country. (He has by far been the main catalyst to our project. We have even found all the original "paper" gaskets that a few were inquiring about earlier in this thread.) The "chrome" parts we have found are in beautiful condition! No scuffs or scratches whatsoever. No reproduction parts!!!
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137527
05/12/09 12:31 PM
05/12/09 12:31 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
...Here are a few photos of the battery.
Hi Dave,
Thanks for the pictures of an assembly line battery. Perhaps you will be providing a repro service for the "correct" battery in our future?
Ola Nilsson
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: cudaized] #137528
05/13/09 02:34 PM
05/13/09 02:34 PM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
Here was an interesting bit of "detail" information that was a surprise for us.
How many people knew that the doors on these vehicles were primed on the back sides of the door skins BEFORE they were mated to the inner door frame structure?
After the car body panels were assembled, the car was then dipped/submerged by the conveyor primer line. The first layer you will see on the back side of the door skin is the light color primer followed by the darker dip color.
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137529
05/13/09 03:19 PM
05/13/09 03:19 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
Hi Dave
They also put the panel treatment (undercoat?) on before the skin was mounted. Same for the quarter panels
performancecarrestorations.com
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: moparo] #137530
05/13/09 07:38 PM
05/13/09 07:38 PM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
Hi Dave
Hi Mauro,
The panel treatment you mentioned is referred to as a Mastic sealer. It was also sprayed on prior to the door skin being mated to the door frame. That particular layer was not used for "corrosive" purposes but as a sound deadened. If that material was not applied to the large metal door skins they would have sounded like a bass drum when they were closed. The same for the quarter panels. Had the Mastic material had not been applied to that area, rocks or any other exterior "knock" would have resonated throughout the enclosed (void) areas. The black color is over spray that blew through the door openings while it was being painted at the factory.
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137531
05/13/09 07:58 PM
05/13/09 07:58 PM
St. Louis, MO
DodgeMaterial Offline
St. Louis, MO
Dave -you are correct. One nice thing about working on such a well preserved and original car is the ability to learn and share with everyone. I confirmed our findings with Mr. Mike Masich. Mike worked in Chrysler stamping during the late 60s and early 70s. He described after stamping a door skin (or quarter panel) they would spray prime and then apply "dumb-dumb" (mastic sound deadener)on the inside, then final assemble the door shell and ship to the assembly plant or parts depot. With this car being so clean you can easily see all of the stages including the overspray in the doors of the assembly plant paints... both blue (interior color) and black (exterior color) are evident and even allow you to vision the strokes of the painter. Hope this helps - Dave S.
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: DodgeMaterial] #137532
05/13/09 11:52 PM
05/13/09 11:52 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
How will you remove all the rust or surface oxidization on the inside of the upper half of the inner door structure as shown in the above picture?
I'm sure it wasn't there when the car was new....and you know we'll want before and after pictures once you're finished
CHECK OUT MY NEW WEB SITE !
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: anlauto] #137533
05/14/09 12:53 AM
05/14/09 12:53 AM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
With rust remover!!?!!?!
Was this a trick question Alan? After spending over an hour to remove oxidation from a screw that was half way under the VIN tag, did you think THIS would really be an issue? When those parts are finished, you will NEVER know they had ANY trace of oxidation whatsoever. (If you like I will send you a complimentary framed copy of the “before” and “after” photos.)
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: anlauto] #137534
05/14/09 01:10 AM
05/14/09 01:10 AM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
Hi Alan,
Help me out with this one! I literally just received an email from someone reminding me of a previous post (about the Cuda in 2005) where someone claimed, THAT particular car did not represent a factory delivered vehicle because there would have been “flash” rust on the bare metal resulting from the water test. I certainly can’t offer both types of “finishes” so what should do I do? Do I take the rust off and have one side argue that it SHOULD be there, or leave it as is and have the other side argue that it SHOULD NOT be there? The other option would be to remove only half of it and be correct on both counts!
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137535
05/14/09 07:06 AM
05/14/09 07:06 AM
anlauto Offline
anlauto  Offline
Ohhhh......so who has the trick questions now....eh???
The answer is quite obivious....and we here at MOPARTS wouldn't expect anything less.....
You need to spend countless hours removing any sign of rust inside the doors, under the dash, rear parcel shelf, etc...
Then without question you need to construct a water test facility to re-create the water test done to this car in 1970....
....then whatever flash rusts in the time it takes you to get this car to the judging block.....be sure to transport it on an open trailer, ...should mimic closely the amount of flash rust that would have been on the car on the dealer's lot.
I'm surprized you had to ask....
P.S. A framed before/after picture will not be neccessary, but thatnks...
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: anlauto] #137536
05/14/09 12:00 PM
05/14/09 12:00 PM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
You just made this too easy! At this point I could say that we DID remove the flash rust and everything you see in the pictures WAS the results of our simulated “water test.” Isn’t that the type of response that prompts the suspicious, rhetoric questions regarding many of the things we are doing or the parts we find? (I especially love the poorly camouflaged “test” questions.)
Don't worry Alan, shortcuts, embellishments or compromised truths will never be a part of the equation. People can safely perceive this project for what it represents. Those who consistently “question” under a suspicious or cynical view are simply exposing their own ilk or personal traits. What you see is what you get!
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137537
05/14/09 12:52 PM
05/14/09 12:52 PM
SE Pa.
SE Pa.
if a car has rust from a "water test" wouldnt that mean it failed the test and should not have be sold to the public?
I say kill the rust and say there is no flash because this is a perfect car and did not leak.
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: badblack68] #137538
05/14/09 01:58 PM
05/14/09 01:58 PM
anlauto Offline
anlauto  Offline
Great...Now we'll need "before", "after" and "DURING" pictures...
Keep up the great work Dave
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: anlauto] #137539
05/15/09 12:54 AM
05/15/09 12:54 AM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
Hey Mr. Alan G! You will never guess what we figured out today after looking at the build sheet to this old jalopy? It takes a GREEN cap Battery. The good thing is that the battery I got from Ed Meyer actually WAS a green cap style. He had an extra set of original yellow caps that we switched out. I am getting the green ones back from him the next time we visit in a few weeks. (They were even in better condition than the NICE yellow ones.) I will post some pictures of those when I receive them. Someone mentioned that the green caps are not reproduced so that even makes the battery a bit more unique.
If there are any other “behind the scenes" photos you wish to see, let me know. We have taken over 500 so far and still clicking away! (Thanks for your input Alan!! )
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: anlauto] #137540
05/18/09 05:42 PM
05/18/09 05:42 PM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
I experimented a little with the removal of the flash rust. I spent about 10 minuets on a small area to show the contrasting difference. (The wiper motor area in the picture was not included.) I should be able to remove all traces of flash rust with no abrasive materials and the metal will look pristine.
I also included a picture of the quarter side marker light area. There was a huge debate a year ago as to whether body components or accessories (with gaskets) were painted on or off the car. Would anyone care to guess how the quarter side marker lights were painted on this vehicle?
Re: TAKING IT TO THE "NEW" NEXT LEVEL!! [Re: ECS] #137541
05/19/09 08:43 PM
05/19/09 08:43 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Hey Dave,
Thanks for the Great Post/ Pictures
Would your be willing to help out with some yellow caps for me to use. I will return them when done
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
