All the racers and people I know that ran a annular booster 4150 carb, had problems controlling the AFR above 5000 RPM, they all went fat
The other bad thing about annular boosters is they take up airspace in the carb. so they limit the total amount of air that the carb will flow at WOT
As much as 80 CFM is what I've been told
I have three Holley 1050 Dominators with the same list # 9375 non H.P., one has been converted to annular boosters, it has jets in it that are 20 sizes smaller, # 72 versus # 92 in the other two and it makes 25 HP less with the same AFR on the same engine on the DTS engine dyno the same day 20 mintes apart with no other changes
It does drive nice on the street, I had to limit the idle fuel feed and the intermediate fuel feed to get it decent(lean enough) enough to not foul the spark plugs at light part throttle cruise bewteen 2000 and 2500 RPM
the other two are rich at part throttle cruise also
