Rocker Arm Pivot Length on BB Mopar #1374589
01/23/13 01:53 PM
01/23/13 01:53 PM
Wildwood, FL
1fastabody Offline OP
Wildwood, FL
Does anyone know what the rocker arm pivot length is on a BB Mopar. I have a set of Victor heads here and I'm looking at machining my own rocker bar and installing some Jesel rockers that I have. Thanks for the help!
Innovative Performance
Re: Rocker Arm Pivot Length on BB Mopar [Re: 1fastabody] #1374590
01/23/13 02:14 PM
01/23/13 02:14 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
20.125" on my HS shafts.
Re: Rocker Arm Pivot Length on BB Mopar [Re: Clanton] #1374591
01/23/13 02:57 PM
01/23/13 02:57 PM
Wildwood, FL
Wildwood, FL
I'm not looking for the shaft length but the length from the rocker tip center to center of shaft. Thats what they consider the arm pivot length, but thanks for the info.
Re: Rocker Arm Pivot Length on BB Mopar [Re: 1fastabody] #1374592
01/23/13 05:58 PM
01/23/13 05:58 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
not exact but 1.565 from OC of rocker shaft to roller tip center line.
