Rocker arm adjuster jam nut torque?
#1374531
01/23/13 12:06 PM
01/23/13 12:06 PM
Posts: 697 Central IL
70Sbird
Central IL
Quick question, Got my pushrods last night for the 440 and am getting ready to install them and button things up. I have Stainless Steel roller rockers from PRW with a 7/16-20 adjuster screw and 12 point jam nut. Once I get the adjustment set how tight does the jam nut need to be? I called PRW's tech line and they told me 15-17 ft/lbs? That seems low to me, especially for a 7/16" fastner Any suggestions? Here is one of my rockers: Thanks Scott
Re: Rocker arm adjuster jam nut torque?
[Re: 70Sbird]
#1374533
01/23/13 12:50 PM
01/23/13 12:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont know anyone that really torques them... I just give them a pull with your standard box wrench.. its maybe 20ft lbs(I use the wrench because I have the allen wrench in it to keep it in location)
[Re: MR_P_BODY]
#1374534
01/23/13 12:57 PM
01/23/13 12:57 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
I've gotten in the habit of checking them all with a torque wrench set at 18-20 lbs after running the valve lash. I do it pretty much just to make sure one of them wasn't left loose.
I have had a threaded adjuster shear on the big end before, lash loosened way up but nothing catastrophic.
[Re: Streetwize]
#1374535
01/23/13 01:20 PM
01/23/13 01:20 PM
MR_P_BODY
I run down each side with the wrench before I throw the valve cover on... I did check the torque one time to see how close I was... its right around 20
[Re: HEMIFRED]
#1374541
01/23/13 05:03 PM
01/23/13 05:03 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
for over 35 years I have used a small dead blow hammer and give the wench a light tap .
Every time I give my wench a light tap she threatens to call the cops - and I don't even use a hammer !!
[Re: Streetwize]
#1374543
01/23/13 06:22 PM
01/23/13 06:22 PM
Posts: 901 oh
julian2007
oh
if you want them to live,dont be a fool use a lsm tool. at least then you will never second guess your self. Most people who call them self a pro uses one. Im not a pro but I do what the pro's tell me to and my $hit lives a long time. I gave 170.00 for mine
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
