HEMI K-frames #1374111
01/22/13 01:32 AM
01/22/13 01:32 AM
X
xx29 Offline OP
xx29  Offline OP
X
will 66-9 B-body HEMI K-frame fit 71 HEMI B-body? Any differences? Besides the sway bar mount? Can it be modified to accept 70-1 swaybar?
Is 70-1 E-body HEMI K-frame same as 71 B-body?
Thanks!
Re: HEMI K-frames [Re: xx29] #1374112
01/22/13 02:43 AM
01/22/13 02:43 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The 68-69 will fit the E body but the steering box angle is different.
I suppose you could cut one off a 318 k and graft it on yours.
I belive the 71 b and E K frames are all the same.
Jamie/Roy at mega parts have been selling a reworked Hemi K frame for 10-15 yrs and pretty much know all the differences..
Re: HEMI K-frames [Re: sthemi] #1374113
01/22/13 03:02 AM
01/22/13 03:02 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Yep, they got their pattern from Al Debevec, call and order one from him or send him yours. Tim
Re: HEMI K-frames [Re: xx29] #1374114
01/22/13 09:58 AM
01/22/13 09:58 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The 71 Bs and Es are different from the rest, the motor also sits in it different than the70 and back Ks. Do yourself a favor and just order one from Mega Parts.
Re: HEMI K-frames [Re: 71birdJ68] #1374115
01/22/13 10:32 AM
01/22/13 10:32 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It will be money well spent , I have one and it's very nice. also note that a real hemi K has a reinforcement added to the steering box mount , just buying the brackets I have seen for sale doesn't get you that extra reinforcement .
Re: HEMI K-frames [Re: JohnRR] #1374116
01/22/13 06:42 PM
01/22/13 06:42 PM
X
xx29 Offline OP
xx29  Offline OP
X
Many thanks for the info!
Re: HEMI K-frames [Re: xx29] #1374117
01/22/13 07:55 PM
01/22/13 07:55 PM
California
mickm Offline
mickm  Offline
California
skid plate is different on 70 and pre 70 as well. not sure what the 71 looks like.
Re: HEMI K-frames [Re: mickm] #1374118
01/24/13 11:02 PM
01/24/13 11:02 PM
X
xx29 Offline OP
xx29  Offline OP
X
is there any part numbers or date codes stamped on factory K-frames?
Re: HEMI K-frames [Re: mickm] #1374119
01/25/13 02:16 AM
01/25/13 02:16 AM
JohnRR Offline
JohnRR  Offline
71 has the same skid plate as 70.
the assembly line K has a COING welded on it wit hthe last 2 digits of the part number as an ID , the NOS E body K i had years ago that came out after production did not have a coin. There should/may be a date stamped on the assembly Line K , it would be the date the engine and trans assembly were attached to the K.
