I'm going to order a rebuild kit for my 23 spline a833. Built in Feb. 1969. It's my first try at it by myself. I bought it in this condition. From the pics, can you tell me if you see anything besides the synchro stop rings needing replacement? I think someone tried to work on it already, the synchro keys (struts) were from an earlier (pre-68) trans, they were the skinny ones with the narrow line across it. The gears look clean and sharp. See anything?
Date code is 2768 or Feb, 24 1969
Stop ring from 3rd gear (bad one)
Clutch hub from 3rd, I just noticed the keys/struts are missing...
1/2 clutch sleeve gear and stop ring
