BBM Indy valve train advice needed.
#1374067
01/22/13 12:52 AM
01/22/13 12:52 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I have a pair of Indy Aluminum cylinder heads on a 470" roller cammed engine. I cannot use the aluminum heads due to class rules, and have some Max Wedge Replacement heads CNCd waiting to go on. I'm planning on taking the heads to a swap meet this weekend to try and sell them to buy other parts for my pulling truck.
Should I keep the pushrods and the Indy rockers and run them a season on my iron heads? Or should I sell them with the heads and move onto purchasing some Hartlands or T&Ds. The motor was not ran hard before and seems in good shape. I will likely be turning this motor 72-7500 rpms(maybe more) in a 4wd pulling truck. I'm on a budget and hope the cylinder heads being sold will help me buy more axle parts, I need to regear both front and read diffs, plus spool rear, locker front, and some axle shafts. If I sell the Indy rockers, I will need to put money into some more rockers and pushrods. Engine currently has a roller cam in it, the specs are not in front of me.
Thanks guys. Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: BBM Indy valve train advice needed.
[Re: MMiller]
#1374069
01/22/13 01:30 AM
01/22/13 01:30 AM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
My Through my experience, I ran Indy 440-1's, and was told to upgrade to Harland Sharpes, and very glad I did. But I did run the pushrods from Indy, and 45-50 runs they started breaking, costing me two races in a row and a nice points lead, which I did regain at the last race,lol. I switched to Smith Bros and never had an issue after that. A friend of mine broke quite a few rockers before switching to Harland Sharpes and not having any trouble since. Hope this helps And for the record, I AM NOT bashing Indy by no means, I have lots of Indy stuff, and am happy with what I have run!!! ![](/ubbthreads/images/graemlins/thumbs.gif)
It's a bigblock with a torque flight!!!
[Re: fourgearsavoy]
#1374072
01/24/13 12:38 AM
01/24/13 12:38 AM
MMiller
Lenox Iowa
You do know that Indy makes cast iron heads also right??? Maybe check out some of the Indy dealers for a possible trade-in value for your MW heads Give Nick a call at www.compu-flow.com ![](/ubbthreads/images/graemlins/thumbs.gif) At least all your other parts will work ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Gus
I have found the need to clarify some things. Class rules state OEM Iron heads. I already have some Max Wedge Replacement heads with correct casting numbers, ported, and assembled. I had them before buying an engine with these aluminium heads on them. The engine has the correct pistons, a decent camshaft and a ton of good parts that I would have spent a bunch more money on building myself.
I do appreciate all the advice, its all been read and tossed around.
Michael
[Re: mopar_to_ya]
#1374074
01/25/13 02:53 PM
01/25/13 02:53 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
My Through my experience, I ran Indy 440-1's, and was told to upgrade to Harland Sharpes, and very glad I did. But I did run the pushrods from Indy, and 45-50 runs they started breaking, costing me two races in a row and a nice points lead, which I did regain at the last race,lol. I switched to Smith Bros and never had an issue after that. A friend of mine broke quite a few rockers before switching to Harland Sharpes and not having any trouble since. Hope this helps DITTO! ![](/ubbthreads/images/graemlins/tongue.gif)
Founder and CEO of the Central Valley Mopar Drag Pack
