Re: Stock - Replacement Thermostat Housing Needed
[Re: faud88]
#1373968
01/21/13 11:02 PM
01/21/13 11:02 PM
Posts: 1,443 Maryland
Dads426
Maryland
I've used the ones from Four Seasons. Order from your local parts store. I believe these are cast iron, not aluminum, but they don't leak like chrome ones. Summit
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: faud88]
#1373969
01/21/13 11:06 PM
01/21/13 11:06 PM
RapidRobert
NAPA might have them in stock
[Re: RapidRobert]
#1373971
01/22/13 08:45 AM
01/22/13 08:45 AM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
I got one from Napa (stock replacement). No leaks. Chrome nothing but headaches!
[Re: faud88]
#1373972
01/22/13 10:43 AM
01/22/13 10:43 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
I will give it a try. I have tried both the chrome and the billet from (Mancini). Both are leaked on top of the aluminum housing.
Thanks!
Did you make sure the thermo housing was flat AND did you remove the chrome off the chrome one ?
what year engine are you working with ? Not all used a steel one .
