I've bought driveshafts at the u-pull-it that have the slip-spline and rear yoke for my trans/rear end yoke application, which is a 904 using 7260 u-joints. Then my local driveline business cuts off the ends and welds them into the appropriate mild steel tubing. Much better than the old, used & rusty original driveshaft tube. I finish it off with solid Spicer u-joints and a billet yoke in the rear.
But double-check with whoever will be doing the work to make sure they can get the correct diameter tubing in whatever thickness they recommend for your ends.
Make sure you find a GOOD, reputable shop and triple check the measuremenst, or have them check it before assembling the shaft.
