Page 4 of 7 1 2 3 4 5 6 7
Re: budget turbo Belvedere still alive and well [Re: TheOtherDodge] #1373406
01/26/13 12:12 PM
01/26/13 12:12 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I'd love to do efi but the problem is finding a suitable controller.
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373407
01/26/13 12:18 PM
01/26/13 12:18 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
http://www.hangar18fabrication.com/blowthru.html
Lots of guys using this mod for blow through. This is only for gas though, no e85.
I wanted to do my own carb too, but i figured by the time I spent screwing around getting it right, dyno/test and tune money, I'd be further ahead just buying one.
I got mine from Eric at Horsepower Innovations. Carb has been awesome, and some of the best tech/customer service I've ever received on any part in my life. Worth every penny spent being able to start the car up for the first time, and instantly going out to enjoy it.
http://www.horsepowerinnovations.com/concrete/
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373408
01/26/13 12:48 PM
01/26/13 12:48 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I'm working on a budget system right now for my 440, 411 LS1 computer with coil on plug ignition on a BB mopar. I pd $33 for the PCM at the local pick-a-part. I hope to have a full writeup on it on moparts before spring fling in a few months.
My brothers shop just built a 1100 hp blown ls gto on E85 using a stock LS computer...it's amazing what these PCM's are capable of.
Re: budget turbo Belvedere still alive and well [Re: Quicksilver440] #1373409
01/26/13 01:08 PM
01/26/13 01:08 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
What vehicle is the pcm out of? The problem around here is there isn't many pick a parts. I have plenty of salvage yards and I haven't seen a brain box cheaper than $100 lately. They were going $50 5 years ago.
The next problem I saw was finding a way to program the said brain box without spending a fortune. Check prices on EFI Live and you will catch my drift. I just don't see it being practical. I'd have to do multiple vehicles to recoup the cost.
Re: budget turbo Belvedere still alive and well [Re: Quicksilver440] #1373410
01/26/13 01:25 PM
01/26/13 01:25 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
What did you do for the crank trigger? Seems like that would be the toughest part. Then what are you tuning with?
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373411
01/26/13 01:55 PM
01/26/13 01:55 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
It wouldn't be the most accurate but the distributor pickup could be used for trigger. A more expensive option would be an MSD crank trigger setup.
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373412
01/26/13 02:37 PM
01/26/13 02:37 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You can't use a distributor. The EFI needs to know where #1 is.
Regular MSD crank trigger doesn't work either because the EFI watches for 28 (can't remember the GM reluctor wheel count?) pulses per rev.
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373413
01/26/13 02:45 PM
01/26/13 02:45 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Oh so the real problem is the cam sensor and not the crank sensor.
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373414
01/26/13 03:08 PM
01/26/13 03:08 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Exactly. But new motors don't use cam sensors anymore because of variable cam timing, so they use the crank with a reluctor wheel to know where #1 is. I was just wondering how to do this on a GM computer with an old mopar crank.
BTW... sorry totally off track to the original post... lol
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373415
01/26/13 03:49 PM
01/26/13 03:49 PM
Central Valley, CA.
Central Valley, CA.
You can get the 411 PCM out of any 1998 to 2002 GM V8 or V6 Truck or F-body, etc.
As far as tuning goes....any LS1 tuner show can do it for you, that's what every Chevy guy does. LS1 tuners are everywhere.....
OR...buy HPtuners software for $499.00 or even cheaper used (I've seen the software for $350 used). I can afford the software when the PCM only cost $33. I bought another PCM on ebay for $25+shipping=like $40 or so total.
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373416
01/26/13 04:01 PM
01/26/13 04:01 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Ati and innovators west (i believe) can make you a balancer with all that built in. And you use the distributor for that cam sync but cutting off 7 reluctors and using the one left to dictate #1
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373417
01/26/13 04:08 PM
01/26/13 04:08 PM
Central Valley, CA.
Central Valley, CA.
I mounted a stock LS1 crank reluctor on a stock crank pulley and used a AndyF crank sensor bracket to mount the sensor on.
For a cam sensor...I took a gutted distributor and mounted a 1X sensor and reluctor in it from a Vortec pickup motor from the junkyard...cost me about $35 at the pick-a-part. I should start another post will all this stuff in it with pics, etc. I took a bunch while doing it....I was just planning on waiting until it was running so I could be the first to do it....lol.
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373418
01/26/13 04:09 PM
01/26/13 04:09 PM
Central Valley, CA.
Central Valley, CA.
All the LS motors except for the very newest ones still used a cam sensor.
Re: budget turbo Belvedere still alive and well [Re: Quicksilver440] #1373419
01/26/13 04:56 PM
01/26/13 04:56 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[I should start another post will all this stuff in it with pics, etc. I took a bunch while doing it....I was just planning on waiting until it was running so I could be the first to do it....lol.
Awesome!!!! That will be a priceless thread. I plant on going turbo. So EFI would be double cool. Will look forward to your post!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: budget turbo Belvedere still alive and well [Re: Von] #1373420
01/26/13 05:00 PM
01/26/13 05:00 PM
Central Valley, CA.
Central Valley, CA.
Will do! I'm trying to get all my pictures together as I redid my laptop so wouldn't lose them...lol. It may have been on one of my external drives in the safe....
Re: budget turbo Belvedere still alive and well [Re: Quicksilver440] #1373421
01/26/13 05:15 PM
01/26/13 05:15 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I also wanted to try a efi setup from a ls deal but
I kept it more simple.
I wouldn't mind going that rout later on though.
That post on doing your own carb is a good start, the E85 sorta throws the numbers off though
I also have 2 power valves on my carb
It kept the cylinder temp more even
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373422
01/26/13 07:03 PM
01/26/13 07:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
carb isn't an issue. MSD had a boost delay/retard box you can add on. It lets you drop from .5* to 4* per lb of boost. The carb and the delay box are a much easier instal than a EFI set-up and WAY cheaper.
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373423
01/26/13 07:13 PM
01/26/13 07:13 PM
Central Valley, CA.
Central Valley, CA.
easier yes...but if you buy a setup forced induction carb, not that much cheaper than my setup once you figure in the ignition and tunability that comes built in the LS1 ignition/Efi.
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373424
01/26/13 09:05 PM
01/26/13 09:05 PM
Temperance, MI
P
P
Temperance, MI
MSD has a digital ignition box (#6530) that has a map sensor. you can program all your timing maps from a laptop and put in set amounts or boost per timing tables
Re: budget turbo Belvedere still alive and well [Re: prochargedhemi] #1373425
01/26/13 10:31 PM
01/26/13 10:31 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Using the LSx coils and 24x reluctor setup would allow for use of the several good systems on the market, in addition to the GM PCM.
Mega Squirt is very popular in the turbo LSX world.
For carb use, I would imagine that you could use the stand alone plug and play type boxes like the MSD 6010/6LS and the Mallory Firestorm.
Neat stuff. Excited to see some developments as they happen.
