Page 1 of 7 1 2 3 4 5 6 7
budget turbo Belvedere still alive and well #1373346
01/21/13 09:05 AM
01/21/13 09:05 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Long time since I been on here
My budget turbo belvedere is still alive and well
I have a clip of a Dyno pull I made last year but not shure how to load it.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373347
01/21/13 09:12 AM
01/21/13 09:12 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
This shot is from the world series at Cordova 2012
Never got a clean pass due to fuel delivery issues, after dyno tune the fuel requirement went up so it made a bad thing worse
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373348
01/21/13 09:33 AM
01/21/13 09:33 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Old pic from old phone
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373349
01/21/13 09:39 AM
01/21/13 09:39 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Once I get fuel system figured out then plans for a bigger turbo are in the works.
But I will proly go threw the 383 first.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373350
01/21/13 09:47 AM
01/21/13 09:47 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
The bang shift crue even stopped by for a interview LOL
They took a bunch of pics of the heap
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373351
01/21/13 09:51 AM
01/21/13 09:51 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Here is one of the pics
With yours truly fighting the hot chicks off with a stick !!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373352
01/21/13 05:29 PM
01/21/13 05:29 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Looks like my kind of build, what turbo are you using? I plan to run a GT45 chinese turbo on my 78 Aspen
Re: budget turbo Belvedere still alive and well [Re: gtsdude] #1373353
01/21/13 06:37 PM
01/21/13 06:37 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i would spend a little more money and get a master power or a borg warner. Those turbos are cheap for a reason
Re: budget turbo Belvedere still alive and well [Re: prochargedhemi] #1373354
01/21/13 09:03 PM
01/21/13 09:03 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
A GT45 is a master power... lol
So to the original poster... how quick is this thing... wanna run 'em?
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373355
01/21/13 09:18 PM
01/21/13 09:18 PM
Temperance, MI
P
P
Temperance, MI
gt 45 is a size designation not a brand
http://www.ebay.com/itm/HUGE-GT45-TURBO-...a08&vxp=mtr
Re: budget turbo Belvedere still alive and well [Re: prochargedhemi] #1373356
01/21/13 10:30 PM
01/21/13 10:30 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Turbo is a Ebay GT45 y2004k, Ebay 53mm BOV and 60mm waste gate.
Its like a 69mm 105AR exhaust, I have 4-5 years on it now with no problems what so ever....
And we are not nice to it at all!!!
Engine is BONE stock 1968 383 never been apart except for.
280/480 comp juice cam, used one I had laying around
double roller chain
chrome timing cover lol
High volume oil pump
And a Torker 383 intake with new valley pan cause the old one was rusted out.
Carb i did myself, it runs on E85
3500 10" stall, colum shift.... I just leave it in drive!!!
3.91 gear witch I will be swapping for 3.23 soon
29x10 Slicks
High 10s @ around 120 so far but fuel system cant keep up so no full power passes yet.
should run low 10s to high 9s @ 130s once fuel seystem keeps up
BTW!!! car is FUN to drive !!!! layer on the wood and let the Turbo do the talkin LOL !!!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373357
01/21/13 10:36 PM
01/21/13 10:36 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Anyone wants to know what all the parts are just send a message...
1968 Belvedere, well worn 383,727,8 3/4,bench seat, lap belt... STOCK!!!
Sure Ill run ya LOL
Ill be at the world series again for 2013 but I usually go to Cedar Falls in Iowa
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373358
01/21/13 11:44 PM
01/21/13 11:44 PM
Temperance, MI
P
P
Temperance, MI
I must say i am very surprised. I have no first hand experience but i know a few locals have tried .60 trims on imports with VERY little luck.
Your car is definitely impressive
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373359
01/21/13 11:49 PM
01/21/13 11:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
LOL... sounds good. How much boost are you running? Intercooler? Fuel?
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373360
01/22/13 01:22 AM
01/22/13 01:22 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
It's not intercooled, E85 fuel from the local kwik trip
I leave the line @ 10 psi of boost
Not shure what it goes to down the track
If I could load the dyno vid you could see it on the Super Flow dyno
I think we stopped at 21-23 pounds of boost, I would have to look at the sheet
The turbo is a single EBay GT45 y2004k for 260-300 bucks
I actually have 2 turbos for twins but didn't feel like relocating the alternator.
It could use a bigger turbo like a BW s475 or s480
On the vid of the dyno pull it was 93+ and high humidity on its 12th pull, she was warm
Said pull made 593 HP and 724 tq
With a 30min cool down 613 HP and 758 tq
I was trying to start the pulls at 3800 but dyno could only bring it down to 4200
With cooler weather I'm shure I could hit 800 on the tq, well or BOOM LOL
Re: budget turbo Belvedere still alive and well [Re: prochargedhemi] #1373361
01/22/13 02:26 AM
01/22/13 02:26 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
My cheap turbo has been on my car for over a year and took some serious abuse including lack of oil, a return restriction, and a few lean conditions in which my pryometer read almost 900 deg. and is still going strong. For $263 to my door vs $600+ I can buy one more before I reach the cost threshold.
Glad to see another person debunking the cast piston/stock motor myth too
Re: budget turbo Belvedere still alive and well [Re: SLOW67] #1373362
01/22/13 03:23 AM
01/22/13 03:23 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Well I got the dyno pull on YouTube
It's on my page but when I search for it nothing comes up, maybe it just takes a bit
Search, Mopar turbo stock 383
I hope it works
It shows the power numbers !!!!
This dyno is verry conservative BTW
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373363
01/22/13 03:43 AM
01/22/13 03:43 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
It says takes up to 48 hours to show up in search
O well I guess ill just have to wait
Re: budget turbo Belvedere still alive and well [Re: SLOW67] #1373364
01/22/13 06:51 AM
01/22/13 06:51 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
900F?
That's rather rich, Reliant goes through the traps at 1700F
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373365
01/22/13 08:14 AM
01/22/13 08:14 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I love reading about these turbo cars. I just haven't found the information I'd like to make me comfortable in trying to make one.(well that and the $$$)
