Re: Considering Switching To Alky... [Re: Cheatham] #1372923
01/24/13 11:00 AM
01/24/13 11:00 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Alcohol is the only way to go if you Bracket Race,a carb. is limited in tuning,an injection system such as Ron's has a unlimted tuning range.You can put as much or as little fuel as you want in the engine with it,and the throttle response is much better.
PS Did not mean for this to be anti-carb. there is nothing wrong with a alcohol carb. just prefer the injectors myself!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Considering Switching To Alky... [Re: MRMOPAR622] #1372924
01/24/13 11:21 AM
01/24/13 11:21 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
My
I run 2 C&S 800 aerosol carbs with a Magnafuel 500 feeding them from 10 gallon cell.
Switched from 2 850 anular Demons a BG 400 and C16 beginning of 09 and won't ever go back !!!!!
Re: Considering Switching To Alky... [Re: RockChip] #1372925
01/24/13 12:45 PM
01/24/13 12:45 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
alcohol carbs are a nice transition. they are an easy way to get used to alcohol. BLP( Bo Laws) is tremendous C&S are also quite good, i have used others ....but injection is killer. if you go that route call james monroe at killerrons he'll set you up. nobody better!
Re: Considering Switching To Alky... [Re: earthmover] #1372926
01/24/13 02:49 PM
01/24/13 02:49 PM
NC
440Jim Offline
440Jim  Offline
NC
nice looking set up jim any front shots of it installed????
This is about it.
Re: Considering Switching To Alky... [Re: 440Jim] #1372927
01/24/13 02:58 PM
01/24/13 02:58 PM
NC
440Jim Offline
440Jim  Offline
NC
And this is the pump/drive mounting while still on the engine stand. The small gilmer belt drives the pump, the 5" regular pulley drives my alternator.
Re: Considering Switching To Alky... [Re: 440Jim] #1372928
01/25/13 12:34 AM
01/25/13 12:34 AM
oroville, ca
tonys68dart Offline
tonys68dart  Offline
oroville, ca
Here is a pic and a link to my set up. I am still learning about this alcohol injection.
http://www.youtube.com/watch?v=Kflbf5OzSlE
