Re: TAKING IT TO THE "NEW" NEXT LEVEL!!
[Re: sixbbl69]
#137289
11/14/08 11:54 PM
11/14/08 11:54 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
how do you know the grease is factory? now i know this reply will be good.
We found the original factory part numbers still embedded in it!
[Re: I go fast]
#137290
11/14/08 11:58 PM
11/14/08 11:58 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Latch must have had an adjustment also.
Believe it or not, the factory line workers actually had to do panel adjustments after they were initially bolted into place.![](/ubbthreads/images/graemlins/wrench.gif)
[Re: 62maxwgn]
#137291
11/15/08 12:45 AM
11/15/08 12:45 AM
Posts: 27,484 So Cal
autoxcuda
So Cal
Maybe you should grab this on for your next project. ![](/ubbthreads/images/graemlins/scope.gif)
http://cgi.ebay.com/ebaymotors/1970-PLYM...1QQcmdZViewItem
Would like to see underchassis pictures of that car. I had a 50K orig mi 67 ChevyII from So Cal. Orig seats, wires, brake drum stickers...
I drove sparingly through a few Iowa winters. Those few winters made the non undercoated chassis look worse than the prior 25 years driving around So Cal.
[Re: anlauto]
#137293
11/15/08 09:22 AM
11/15/08 09:22 AM
sixbbl69
Was grease applied at the factory? At the dealer during PDI? or at it's first oil change?
depends on where he decides it was put on.this stuff is made up as the project goes along.the only way this car is going to end up like he said it was going to be in early post would to have left it alone. but this is typical of all his post. says 1 thing but totally different at the end.isn't this all about getting attention?? ![](/ubbthreads/images/graemlins/bow.gif)
[Re: JulesdaWiperman]
#137296
11/15/08 12:13 PM
11/15/08 12:13 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Sounds simple enough...But know Dave has a small quandry on his hands.....Because his intentions are to make the car look "NEW" like it's 1970 all over again...How will he be able to tell what colour the grease was 38 years ago? Did it start off white and turn yellow with age or was it always yellow and never changed colour....???? Same with the glue squeeze out on the weather-strip??? It appears dark yellow almost brown, but 38 years ago was it bright yellow like the 3M stuff we're used to today? I'm certain that's why Dave took on this project...to dicover all the secrets hidden before our eyes ![](/ubbthreads/images/graemlins/scope.gif)
[Re: sixbbl69]
#137297
11/15/08 01:02 PM
11/15/08 01:02 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
No sixbbl69.….you got it all wrong! I leave the tough questions up to guys like you and sixpackwagon. Speaking of tough questions sixbbl69, what about that question I asked you regarding seeing and inspecting my Challenger in person? You Talked as if you had seen it first hand, expressing your expert opinions but never acknowledging whether you had actually seen it or not. Please assure us that you are not one of those people who make definite remarks with no factual support whatsoever. With that said, what was your assessment of the grease on this trunk latch when you inspected it? Did you also think that if felt a bit “rubbery” from being exposed for so many years? And for our resident expert sixpackwagon, don’t you know how the factory assembled many of these trunk latches? Please give us your synopsis on how this particular latch was installed and the detailed assembly sequence on how/why the “chipped paint” occurred on the attaching bolts. I am sure all of us following this topic would like to hear your wisdom and interpretation of the procedure!
[Re: I go fast]
#137300
11/15/08 02:03 PM
11/15/08 02:03 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
**No,maybe you should just quit posting until the d*mn things finished then everyone can tell you how great you are."again".**
I knew that class I took on “envyology” would come in handy someday. Here is what your comment translates to be:
** “I am a jealous person who can’t stand anyone that I don’t know, having or obtaining anything that I don’t have.” **
Get a life! A six cylinder 4 door Valiant is hardly the vehicle to have an “attitude” or problem with!
