How to keep the ac/heater fan resistor from failing T&C #1372571
01/20/13 12:09 AM
01/20/13 12:09 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
It seems that the last three years I've had to replace the A/C-heater fan speed regulator/resistor once a year. Lucky I bought the $100 resistor from Auto Zone with a life time replacement warranty but that doesn't mean anything when it fails and the fan goes to wide open/full fan speed and you have to order a new one and replace it
I don't know how to track down what is causing them to fail but I'm thinking one thing might be a bad voltage regulator or something that one of you guys might know what I should be looking for?
This is the exact regulator/resistor that I can now replace in less than five minutes but what a PIA to have to order, go get, and return the bad one every year, what besides made in Mexico/China is making them fail now? Any suggestions would be greatly appreciated
Re: How to keep the ac/heater fan resistor from failing T&C [Re: A12] #1372572
01/20/13 12:43 AM
01/20/13 12:43 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Glad to see I'm not the only one with this problem. Replaced the resistor in a '98 Concorde, it lasted one week. Let it go for a while and decided to replace it again. Lasted one week again. I suspect the blower motor is going bad causing the resistor to overheat.
Re: How to keep the ac/heater fan resistor from failing T&C [Re: GODSCOUNTRY340] #1372573
01/20/13 03:43 AM
01/20/13 03:43 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i would check the motor ground or switch
Re: How to keep the ac/heater fan resistor from failing T&C [Re: ademon] #1372574
01/20/13 08:42 AM
01/20/13 08:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
probally the motor pulling too many amps.Caddy years ago had the same problem.You had to test the motor to make sure the amps werent high or it ate the resistor.They were one of the first to have a transistoried one.Rocky
Chrysler Firepower
Re: How to keep the ac/heater fan resistor from failing T&C [Re: A12] #1372575
01/20/13 12:43 PM
01/20/13 12:43 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Aftermarket ones are garbage, Pony up and spend the money for a OE one.
Most times the root cause of them failing is the Motor drawing too much current on start up.
Rick
