Disc brakes #1372275
01/19/13 03:55 PM
01/19/13 03:55 PM
MO
C_Notch Offline OP
C_Notch  Offline OP
MO
Anyone put disc brakes on the back of their truck?
Trying to lay out a plan and am curious what others might have done.
Re: Disc brakes [Re: C_Notch] #1372276
01/19/13 04:37 PM
01/19/13 04:37 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Doctor Diff sells a kit
Re: Disc brakes [Re: 76dodgeboy] #1372277
01/22/13 08:19 PM
01/22/13 08:19 PM
dogdays Offline
dogdays  Offline
www.doctordiff.com I believe it is.
Basically, anything that uses as many stock parts as possible is good. Talk to him first.
R.
Re: Disc brakes [Re: dogdays] #1372278
01/22/13 11:39 PM
01/22/13 11:39 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Or look in the forsale section for diff parts
Re: Disc brakes [Re: 76dodgeboy] #1372279
01/23/13 02:08 AM
01/23/13 02:08 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Large bolt pattern or small 4 1/2" pattern
Re: Disc brakes [Re: BulletBob] #1372280
01/23/13 02:14 AM
01/23/13 02:14 AM
MO
C_Notch Offline OP
C_Notch  Offline OP
MO
5x4 1/2
Re: Disc brakes [Re: C_Notch] #1372281
01/23/13 05:11 AM
01/23/13 05:11 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Get the system off the back of a 95 Grand Cherokee..
I am truckless..
Re: Disc brakes [Re: 340SHORTY] #1372282
01/24/13 05:42 PM
01/24/13 05:42 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
will this work on a 8.75?
Re: Disc brakes [Re: 72d100] #1372283
01/24/13 07:49 PM
01/24/13 07:49 PM
dogdays Offline
dogdays  Offline
Backing plates bolt on, drum fits over the studs on the axle, so, "yes". So I've heard.
R.
Re: Disc brakes [Re: C_Notch] #1372284
01/24/13 11:46 PM
01/24/13 11:46 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I put those Cherokee brakes on my '99 Dakota. I had to drill the hats for 6-lugs, but all of the flanges lined up exactly correctly. I just had to open up the bolt sizes and wheel centers for my 9.25 rearend. Supposedly, you won't need to do any of that with the 8.75. I also didn't need to even mess with the proportining valve. It stops great!
Re: Disc brakes [Re: Duner] #1372285
01/25/13 12:29 AM
01/25/13 12:29 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have used rear rotors from a IROC a pair of $12 caliper brackets 2 reman 78-9 G body GM calipers for the front & matching hoses I had to have .100 machined off the outer flange of the axles to fit inside the rotors it costs around $200-250 new parts & labor even less if you own a welder
I have done them with all Speedway motors parts that the Circle boys use
My next one I'm doing I'm going to use the clamp on bracket You can do the total trick look calipers & all for $300 or so pick your own offset on the rotors 12" brakes can be done for a little over the $300
Thats with vented rotors that won't squeak like the the solid ones do on the street
Re: Disc brakes [Re: BulletBob] #1372286
01/26/13 11:08 PM
01/26/13 11:08 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
What car , truck, etc will fit on the back of the 1984 1/2 ton 4x4?? is there a cross reference that someone came up with?/ how did you guys figure this out? let me know before i do the back brakes on this 84 !!
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Disc brakes [Re: hulmule] #1372287
01/27/13 12:18 AM
01/27/13 12:18 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I worked & managed a very large F body GM & musclecar salvage yard for 6 years
We built a bunch of low budget Hot Rods & fast street cars
We had a pile of different brake rotors The bolt pattern doesn't really matter You drill a new pattern or elongate what pattern you have
The composite rotors on the newer stuff 90's & up is a great place to look go to your local JY with a caliper or a tape & the axle or find your same axle there & find what's the closest match
I've done a bunch of low budget rear disc on just about every rearend made using salvage yard parts
Re: Disc brakes [Re: BulletBob] #1372288
01/27/13 04:45 PM
01/27/13 04:45 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
looks like the salvage yard is going to seem me this week.v Thanks
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Disc brakes [Re: hulmule] #1372289
01/27/13 08:10 PM
01/27/13 08:10 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
get a set of rotors off of a late 70s Ford 1/2 ton 4X4..
I am truckless..
Re: Disc brakes [Re: 340SHORTY] #1372290
01/27/13 08:26 PM
01/27/13 08:26 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
80's-early 90's 4wd too
Re: Disc brakes [Re: BulletBob] #1372291
01/27/13 08:32 PM
01/27/13 08:32 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
they had disc brakes on the rear of early fords??
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Disc brakes [Re: hulmule] #1372292
01/27/13 09:15 PM
01/27/13 09:15 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
the fronts on some slid off & on on some years the later I think 97 & up Ford truck I'm sure would be an easy fit Just remember there's a good chance that what fits your axle will most likely have to be modified in some way or another to fit.
Using GM calipers is beneficial in that you can go to the parts store & get what you need cheap & you can get custom calipers for cheap & still go to the parts store & get brake pads to fit
If you want parking brakes you use 82-88 F body GM rears & hoses & cables
If you use any calipers newer than 78 they are metric lines so you will have to put the metric fitting on your steel line to use it just cut & reflsre
