rear track wider than front ??? #1372144
01/19/13 11:29 AM
01/19/13 11:29 AM
Southwest MO USA
417guy Offline OP
417guy  Offline OP
Southwest MO USA
Hey Guys,
I'm planning my rod build and realized that my rear axle hub to hub will be 5" wider than the front ! I'm using an 8 3/4 out of an E body, and a Speedway front axle/spring kit. It's a 39 Plymouth pickup hot rod, no fenders. 330 desoto hemi waiting for it. Any input about the safety and handling of this ? I think it will look ok, but want to be safe and handle well !!
Thanks for any thoughts.
Re: rear track wider than front ??? [Re: 417guy] #1372145
01/19/13 12:36 PM
01/19/13 12:36 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
It will be fine,its done all the time.Not really any different than say if you put some wide tires on the rear of a muscle car
Re: rear track wider than front ??? [Re: wannadrag] #1372146
01/19/13 12:51 PM
01/19/13 12:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
For handling purposes it's better to have a wider front track, assuming front engine. But the opposite won't really be an issue.
Don't be the exception.
Re: rear track wider than front ??? [Re: 417guy] #1372147
01/22/13 08:34 PM
01/22/13 08:34 PM
dogdays Offline
dogdays  Offline
It'll look weird if you have the tires way out there by themselves, that's my first thought. Maybe some FWD rims with a lot of positive offset are in order? Or find a narrower rear.
R.
Re: rear track wider than front ??? [Re: dogdays] #1372148
01/23/13 12:14 AM
01/23/13 12:14 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Choose the offset of the front and rear wheels carefully. 2 1/2" per side is not a huge deal as long as you don't compound the problem with deep offset wheels on the rear and skinny no offset wheels on the front, unless you are going for that late 60s look. If you are going for the late 60, go really big in the rear and as skinny as possible in the front with a huge blower sitting on top of the motor and the mandatory chrome ground torching Zoomies. Gene
Re: rear track wider than front ??? [Re: 417guy] #1372149
02/04/13 11:55 PM
02/04/13 11:55 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
B-body rear is narrower. I'd swap it out. Look them up.
http://www.moparts.org/Tech/Archive/axle/17.html
Re: rear track wider than front ??? [Re: sixpack4spd] #1372150
03/04/13 11:35 PM
03/04/13 11:35 PM
merrill, wisconsin
V
voigtspeed Offline
voigtspeed  Offline
V
merrill, wisconsin
1929 model A front 1971 imperial rear.
Handles great went with wider in the rear to follow the wedge layout of the car.
mock up your car with the wheels and tires and stance you like and add axeles and suspension to fit the overall look block everything up to get it right first.............
ACCELERATION SPECIALIST
