Waterless Coolant
#1371983
01/18/13 09:44 PM
01/18/13 09:44 PM
Posts: 171 Northeast Ohio
BahamaA12RR
Northeast Ohio
Is anyone using Evans Waterless Coolant? www.evanscooling.comWas thinking of using it in my A12. Any opinions, or observations? Thanks, Joe
"Call the doctor- I think I'm gonna crash"
Re: Waterless Coolant
[Re: BahamaA12RR]
#1371986
01/18/13 11:12 PM
01/18/13 11:12 PM
Posts: 224 Kentucky
ewolfe
Kentucky
I've been running Evans in my 66 Hemi Charger for about 5 years now and love it. I'm running a 472 with the numbers matching rad and 5 blade fixed fan...never breaks 180, no matter how long I idle or how mean I am to it It's worth the money. The down side is you need to order extra to have on hand as you can NOT add water...ever. I've not had to add any, but the surface tension is VERY thin and will leak where water will not so you system has to be tight. My lower rad hoses had to have worm clams to keep the Evans from leaking as the factory style tension clamps weren't cutting it.
[Re: BahamaA12RR]
#1371987
01/19/13 10:07 AM
01/19/13 10:07 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I have running Evans NPG waterless coolant for over ten years now in a 1995 5.9 V8 Ram.
I originally decided to try it to see if its claims of reducing pinging at wide open throttle were true.
I found no difference in pinging after the change.
The NPG coolant certainly does not boil over even as high as 300 degrees F, as i have seen those temps when a thermostat failed in the closed position.
My older NPG does have a quirk, at temperatures below 25 degrees F its viscosity is high enough that you have to keep RPMs higher to force it through a radiator unless you have a winter front on the grille.
I understand that the newest formulation onf NPG+ does not do this as it has a viscosity lowering additive package.
I have a restriction in my bypass hose that i placed there to see if more flow to the radiator would make a change, but i could detect no difference.
Note that to get the Fuel economy improvement with NPG coolant you need to go to a much higher temperature and thermostat setting, perhaps 230 to 270 F.
I do not presently know of any thermostat available for Magnum V8s over 205, Or 213 degrees for other engines, So how does one practically try out the high coolant temperatures besides manually blocking airflow to the radiator?
At these higher temperatures you need hoses and gaskets rated to these higher temperatures, and rubbery items may still have shorter liives before failures.
The concept of 3 to 9% better MPG at 270 degrees F instead of 195 degrees is probably technically sound.
I am still on my original water pump and it may be possible that rotating seal life is better with the more lubricating NPG, and cavitation wear on the impellor may be less. Corrosion on internal surfaces may be less too.
I think the people who answer the telephone or emails about technical questions at Evans are BS'ers though, coming from a mining engineer prospective.
[Re: 360view]
#1371988
01/19/13 01:48 PM
01/19/13 01:48 PM
Posts: 6,007 Salem
Grizzly
Moparts Proctologist
Salem
360View: How about taking your fan off and half-blocking the rad (top half, better aero )? I went electric fan on my 360 Mag and can get the temp up there with the switch shut off around town. Out on the highway though it goes back to 195 and stays there. Would have to block it a bit out on the road.......like the '13 Rams....... SRT Rams started it: they have block-off shields in the front too.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1371989
01/19/13 04:56 PM
01/19/13 04:56 PM
Posts: 10,732 North Dakota
6PakBee
North Dakota
I just emailed them and asked for an MSDS. We'll see what pops out.
[Re: Mattax]
#1371992
01/22/13 09:25 PM
01/22/13 09:25 PM
6PakBee
North Dakota
I got the MSDS back. Looks like it's nothing really special. COMPONENT INFORMATION 00107-21-1 Ethylene Glycol ** 00057-55-6 Propylene Glycol - - - - - - Proprietary Corrosion Inhibitor Package
[Re: 6PakBee]
#1371993
01/23/13 01:34 PM
01/23/13 01:34 PM
Posts: 8,162 USA
360view
USA
http://en.wikipedia.org/wiki/Propylene_glycolSample quote Propylene glycol is considered Generally Recognized As Safe by the U.S. Food and Drug Administration, and it is used as an humectant (E1520), solvent, and preservative in food and for tobacco products, as well as being the major ingredient in the liquid used in electronic cigarettes (along with vegetable glycerine and, more rarely, PEG 400). It is also used in pharmaceutical and personal care products.[4] Propylene glycol is a solvent in many pharmaceuticals, including oral, injectable and topical formulations, such as for diazepam and lorazepam that are insoluble in water, use propylene glycol as a solvent in their clinical, injectable forms[6]. Like ethylene glycol, propylene glycol is able to lower the melting point of water, and so it is used as aircraft de-icing fluid.[4][7] It is similarly used as automotive antifreeze.[8] Propylene glycol is an ingredient in the oil dispersant Corexit, used in great quantities during the Deepwater Horizon oil spill[9][10]
[Re: 360view]
#1371994
01/23/13 01:43 PM
01/23/13 01:43 PM
Posts: 8,162 USA
360view
USA
http://www.westmarine.com/webapp/wcs/sto...05#.UQARtXy9KSMSample quote Ideal for all engine uses A nontoxic, virgin propylene glycol formula for superior engine protection during storage or operation. Inhibitors protect against corrosion, and additives help prevent breakdown at high temperatures. Biodegrades rapidly. We do not recommend usage at full strength in engine systems. Not for use in potable water systems. Use as a coolant in the summer and as antifreeze in the winter 96% propylene glycol may be diluted to the solution you wish Special additives guard against slime and scale Not recommended for use full strength in engine systems Not recommended for use in potable water systems End quote (Evans NPG+ has a different additive package. In their original instructions years ago Evans said to flush your system prior to adding their product with the "Sierra" propylene glycol antifreeze available back then.)
[Re: astjp2]
#1371996
01/23/13 02:11 PM
01/23/13 02:11 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Its a novel idea....but when you get a hole in your radiator from whatever reason, maybe a bird you will be scurrying to get under the car and collect as much coolant as you can with any vessel available from a cloth to a can. There is no expansion which is great, no pressure to push against the system.
I dunno how to go about putting it in your existing system, your heater core is going to hold more than three percent, gonna have to make sure everything is sucked out, blown out, dried up and then start adding....still...I can't see myself spending $160 on it....If it were half price I would think about it because of the potential dielectrolysis in my system but I have zinc anodes in place to escape whatever I can
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
