Re: will a 340 crank work in a 360?
[Re: speedfreak]
#1371929
01/18/13 06:57 PM
01/18/13 06:57 PM
RapidRobert
I was thinking that someone at one time did sell bearing spacers that would make up the distance to let you do that then line bore/hone. Might check Mancini/Summit/Hughes etc sites & see what you see. I'd pump it up before you tear it down if you can & as you know then when torn down a good visual for cracks/flatness check/head bolt torque/depth check/gasket condition on the Dr side deck
