Re: milodon oil pan
[Re: 70moparmike]
#1371888
01/18/13 04:59 PM
01/18/13 04:59 PM
Posts: 5,360 Planet Earth
RoadRunnerLuva
Planet Earth
Try contacting them directly to give you the needed specs...here is their info, good luck:
HOME *ON-LINE ORDERS* HOW TO BUY INSTRUCTIONS CONTACT FIND PART COST
Milodon Inc. 2250 Agate Court Simi Valley, Ca 93065
Telephone Phone: (805) 577-5950 Fax: (805) 577-7540
Customer Service / Technical Support It's hard to talk shop with our customers while playing e-mail tag. We'd like to talk to you one-on-one about your exact equipment and the needs specific to your application.
Call us direct at (805) 577-5950 from 7:30 am to 4:30 pm (Pacific Standard Time), Monday through Friday, and talk to us in person. That way, we can help you better than we could electronically!
Plymouth Makes It!
Re: milodon oil pan
[Re: dOc !]
#1371889
01/18/13 05:00 PM
01/18/13 05:00 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Here is one i have my eye on but dont have the part number handy,
Founder and CEO of the Central Valley Mopar Drag Pack
Re: milodon oil pan
[Re: mikeysmopars]
#1371890
01/18/13 05:01 PM
01/18/13 05:01 PM
mikeysmopars
fresno ca
Other side
Re: milodon oil pan
[Re: Mopar Guy]
#1371896
01/18/13 05:27 PM
01/18/13 05:27 PM
Posts: 10,239 Someplace you aren't
SomeCarGuy
The only thing that was tight on my 383 with the 31580 and 1 7/8 Hookers was the centerlink/ idler area when the steering wheel was not centered. Got that corrected and it only got close at the extreme travel. Not even an issue then really.
I want my fair share
Re: milodon oil pan
[Re: Beep Beep]
#1371902
01/19/13 12:33 AM
01/19/13 12:33 AM
Posts: 294 indy
70moparmike
indy
thanks beep beep. that is what i wanted to see! looks like plenty of room. why is that pan so expensive? did all hp 440's have skid plates on the k frames? i noticed yours did have one, thought they were for hemi's only? thanks for the reply's.
Re: milodon oil pan
[Re: autoxcuda]
#1371904
01/19/13 12:58 AM
01/19/13 12:58 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
contacted milodon and they have a pan for ground clearance 31580, but not on tti header list for fitment? pan they reccomend is 2 and a half inches taller? would like to see a street car with one on it to see about ground clearance.
TTI headers fit 440 and Hemi with the 31580 pan.
Really depends what you have you front right heigh set at. Need to compare the distance between the ground and your K-member.
IMHO, if there are ANY marks on the bottom of your TTI headers now, you will have marks on the bottom of that 7" Milodon oil pan.
If you would like to check clearance and your indiviual driving situation, duct tape a stryofoam block across the K-member under your pan that is 1.75" down from your current 5 qt pan.
Here's a past discussion:
https://board.moparts.org/ubbthreads/show...amp;Search=true
This is a stock 6 quart hemi pan (originally came with skid plate) on the left and the 7 qt on the right.
The picture on the pan on the left looks like the early 1966 to 1969 Street Hemi pan, which came with the skid plates stock. They are a good oil pan, I've used many of them The 1970/71 Street Hemi and 440 6 pak pans are better They are shallower with a longer sump and they hold more oil than the early street Hemi pans do OP, look at buying one from Mopar (costly), Summit or Mancini ,I use the stock 3/8 pick up for THAT pan They work good, last a long time I use them in every car that they will fit in, 1966 to 1973 B bodys, 1970 to 1974 BB E bodys and BB in A bodys if you move the motor back and grind the K member back lip in some around the oil pan
Re: milodon oil pan
[Re: 70moparmike]
#1371905
01/19/13 04:46 AM
01/19/13 04:46 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
....why is that pan so expensive? ...
That pans is much more time consuming to make and has many more parts to it.
There are 5 little trap doors inside the sump at each gate. They maintain oil around the pickup under braking, acceleration, left corners and right corners. And there are two trap doors in each left and right kickout. There are also large shelves in the front and rear of sump to keep oil from spilling out of the sump into the front or rear pan area under acceleration and braking.
There's much more length of welding to that pan and more complicated too.
