BUILD MY 493 TOP END
#1371660
01/18/13 01:40 AM
01/18/13 01:40 AM
Posts: 1,039 ALBERTA CANADA
CUDA8U
ALBERTA CANADA
long lasting and tough,
street car,3:55 gears,auto 2800 tci,hydraulic cam ,pump gas,manual brakes,want a raunchy idle
heads? cam? valve train? carb? intake?
i have a m1 single,850 holley
Re: BUILD MY 493 TOP END
[Re: CUDA8U]
#1371663
01/18/13 03:22 PM
01/18/13 03:22 PM
Posts: 46 MT
cudabruce
MT
Here's what I did on my 493 stroker: 4.15 crank Ross dished pistons, 10.6 Compression Ported Eddy RPM heads Racer brown cam STH-42 Roller rockers, 1.7-I 1.6-E Ported sd holley intake 850 Speed Demon annular carb on nitrous plate TTI headers 2" primaries Idles at 900 rpm, This thing pulls incredibly hard and sounds wicked. I'm still not ready to turn the nitrous on.
[Re: CUDA8U]
#1371664
01/18/13 03:46 PM
01/18/13 03:46 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Big motors need big heads, big cam,big headers and high volume fuel system If you want to use the intake and carb, they will work fine once the carb. is tune properly, then buy a set of heds that will flow the most air for the 440 port size, ported Eddy RPM, ported Stealth, ported EZ or ported B1-BS I wouuld put a two inch spacer under the carb. to increase the plenum volume.I would buy a set of Harland Sharp roller rockers, especailly for the street As far as a shelf cam I would use the Comp Cams XE295HL with 1.6 rocker ratio, I have a motor with those parts in it and they work real well, especially the idle I put it in at 3 degrees advance. On headers a set of two inch should work well, a two step of 2 to 2 1/8 inch will be worth a little more power but not a bunch Three or three and half exhaust sytem with a really good set of muffs and you will need some really good rear tires
[Re: cudabruce]
#1371665
01/18/13 03:55 PM
01/18/13 03:55 PM
Posts: 12,073 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My version is similar; Eddys or EZs (porting by Modern optional) I use the Eddys ported by Modern 10.5 CR +/- (I have about 10.9 CR) At least 950cfm carb Any number of good rocker choices Dwayne Porter or Scott Brown for the cam (I use Scott) Depending on the final combo, 600+ Hp on pump gas is easily attainable. With a Dominator, my 499" makes 520RWHP on pump gas. Just be sure to leave some budget for tires.
Master, again and still
[Re: DaveRS23]
#1371666
01/18/13 08:57 PM
01/18/13 08:57 PM
Posts: 7,664 IN
ahy
IN
My combo: Dish pistons at zero deck for 10.2 cr Eddy's, pocket ported Comp Pro Magnum steel alloy rockers MP aluminum rocker shaft hold downs MM lobe solid FT cam speced by Muscle Motors. 242@.050 duration, .55 lift, 108 CL 3/8" pushrods made to fit On the cam, "streetable" is a personal choice. 242 degrees/108 cl has a "noticable" idle and is about as high as you can go if you are using power brakes. If/when I want more from mine, I'll work on head flow and keep the cam about where it is.
[Re: ahy]
#1371667
01/19/13 01:35 AM
01/19/13 01:35 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
My combo:
Dish pistons at zero deck for 10.2 cr Eddy's, pocket ported Comp Pro Magnum steel alloy rockers MP aluminum rocker shaft hold downs MM lobe solid FT cam speced by Muscle Motors. [Email]242@.050[/Email] duration, .55 lift, 108 CL 3/8" pushrods made to fit
That's a pretty aggressive lobe for the street.
[Re: 64Post]
#1371668
01/19/13 11:34 AM
01/19/13 11:34 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I just went down 10* for a little better idle, but here are my cam specs;
.609/.606 and 251*/264* Scott Brown flat solid
3,450 lb street car, 727, 3.91s
[Re: 383man]
#1371670
01/19/13 03:13 PM
01/19/13 03:13 PM
64Post
Baltimore/Denver
I dont think I gave my cam specs. Its a solid flat tappet thats a custom grind frome Dwayne Porter. It is 264 & 270 at .050 with a 110 LSA. It has .588 and .592 lift but I use 1.6 rockers for .628 and .631 lift. I have it in the eng on a 106 centerline. I drive on the street all the time with it and I love it. Has some nice rump rump that I love and idles good for what it is. Makes good power down low up to 6500 or more. 64Post has heard my car as we see each other at local weekend cruise spots all the time. I even still have power brakes that work with ok with this cam. Ron
Yeah, if I was going to do a RB top end it would be very similar, if not exactly, like yours Ron. That's a very good running and great sounding combo.
[Re: DaveRS23]
#1371671
01/19/13 05:24 PM
01/19/13 05:24 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Is that on a wide lsa?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
