Big Block Rods
#1370446
01/15/13 09:37 PM
01/15/13 09:37 PM
Posts: 150 Des Moines, IA
CoreyWilson
Des Moines, IA
Looking for a rod for my RB build spinning up to 7500rpm. We were going to use Manley's H beam rod, but it now looks like they've been discontinued. I've been hearing back and fourth about K1's quality so I don't know what to think about them at the moment. Searching around I came across a forged I beam from Howards Cams rated up to 1000hp part number BR6760. The rod looks good, atleast on paper, but I'm waiting to hear back from Howards about the rod width. So, has anyone used this rod or had any experience with them? http://www.summitracing.com/parts/hrs-br6760-990thanks for the help!
Re: Big Block Rods
[Re: CoreyWilson]
#1370447
01/15/13 09:52 PM
01/15/13 09:52 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Is this for truck puller?
RIP Monte Smith
Re: Big Block Rods
[Re: CoreyWilson]
#1370453
01/16/13 12:59 AM
01/16/13 12:59 AM
Posts: 977 Colorado
506RR
Colorado
506RR,
looking back over a few of your posts I see your spraying your motor, which with my understanding of NOS would probably add to the stress on the rod, right? How many passes have you put on the new rods? Have you torn down since installing them? Do you know how they checked out ootb? So far the only downside I see to the rods is the 1.07" big end width, but I'm waiting to hear back from Howards to see what they measure as well.
thanks for the info!
No passes on these new ARP 2000 rods yet. We have been using the Eagle rods below these with the 8740 rod bolts for the last few seasons. No problems. Measured great after this last season. Upgraded to the new rods for peace of mind because we are turning up the power in 2013.
New rods are currently at machine shop. They should be getting measured this week.
Lots of guys running Eagle rods with quite a bit more horsepower than I make, with a lot more nitrous than I am spraying.
Re: Big Block Rods
[Re: Kevins493]
#1370456
01/16/13 01:51 AM
01/16/13 01:51 AM
Posts: 903 Saskatchewan, Canada
cudabin
I recommend Oliver pro billet rods... We spin the 557" to 8,100 rpm at the traps!
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Big Block Rods
[Re: NTOLERANCE]
#1370457
01/16/13 07:22 AM
01/16/13 07:22 AM
Posts: 976 ontario canada
mac56
ontario canada
Do you have to use a Chrysler rod? Chevy rods are less money for higher quality parts. It would pay to grind the crank so you can run a Chevy rod.
Are you talking about machining a crank to accept the chevy big end diameter and width? Or using a chev rod with a mopar big end width?
Andy will be talking about all chev dimension rods and run with the extra side clearance on the big end. That will be how you get a good rod at a good price. ![](/ubbthreads/images/graemlins/beer.gif)
Re: Big Block Rods
[Re: NTOLERANCE]
#1370459
01/16/13 10:11 AM
01/16/13 10:11 AM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
BME alu rods sees close to 8000 at the strip.
So far so good
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Big Block Rods
[Re: tboomer]
#1370462
01/16/13 12:29 PM
01/16/13 12:29 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I have been running the Ohio Crankshaft I-beam rod in my 499" since 2008. I am happy with them and they were good out of the box. I did have them checked. http://ohiocrank.com/ibeam_rods.html
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
