Valve cover spacers/risers #1369670
01/14/13 10:27 PM
01/14/13 10:27 PM
Atlanta Indiana
Dave Watt Offline OP
Atlanta Indiana
Is anyone aware of small block valve cover spacers/risers that are thicker than 3/16"? A buddy wants to run stock valve covers with Harland Sharp rocker arms. I think it would take at least a 1/4" or more to do it without removing the baffles.
Has anyone tried it before?
Thanks,
Re: Valve cover spacers/risers [Re: Dave Watt] #1369671
01/14/13 10:34 PM
01/14/13 10:34 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Someone here on the board was talking about producing some spacers but I dont recall how thick or if they did go into production.
I am truckless..
Re: Valve cover spacers/risers [Re: 340SHORTY] #1369672
01/14/13 10:56 PM
01/14/13 10:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I make 'em. 3/16" has worked for me & everyone else I've sold them to so far. HS rockers on 2 of my motors. If you did need more thickness, just double-gasket them; I've just bonded them to the heads and used a single gasket.
I have them for BB & LA SB. I have an ad in the Race & BB sections.
Re: Valve cover spacers/risers [Re: Dave Watt] #1369673
01/14/13 11:05 PM
01/14/13 11:05 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I have made them out of wood with a router before. Kinds messy, but totally functional and inexpensive.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Valve cover spacers/risers [Re: topside] #1369674
01/15/13 09:14 AM
01/15/13 09:14 AM
London, England
Gavin Offline
Gavin  Offline
London, England
What did you use to bond them to the head? Thanks!
Re: Valve cover spacers/risers [Re: Gavin] #1369675
01/15/13 12:01 PM
01/15/13 12:01 PM
Atlanta Indiana
Atlanta Indiana
Thanks for the replies. I had seen 3/16" ones on ebay but didn't think they would be thick enough for the baffles to clear the rocker arms.
We used the Permatex Ultra Black to hold the spacers to the valve covers on a small block Chevy.
Re: Valve cover spacers/risers [Re: Dave Watt] #1369676
01/15/13 01:38 PM
01/15/13 01:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ultra black like Dave says works fine; you could use something more permanent, but it's not necessary. Yes, we also sell them on Ebay.
Re: Valve cover spacers/risers [Re: topside] #1369677
01/15/13 02:49 PM
01/15/13 02:49 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
I have the Crane gold roller rockers for my 360 and plan on using the stock valve covers - will they need to be spaced as well?
Re: Valve cover spacers/risers [Re: 76Beeper] #1369678
01/16/13 08:40 PM
01/16/13 08:40 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have the 3/16" on my big block with HS rockers. I used a felpro rubber gasket on both sides of the spacer. I glued the spacer to the top gasket which I glued to the valve cover.
Worked out great.
Re: Valve cover spacers/risers [Re: BBR] #1369679
01/17/13 03:14 PM
01/17/13 03:14 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
What kind of wood? The reason I ask I was just entertaining this very thought for some Magnum style heads.
