Re: 440 Six Pack Nitrous Install [Re: 6PKRTSE] #1369135
01/16/13 02:32 PM
01/16/13 02:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
No offense, but no sir. No cowl Chevy hood will ever wind up on my cars. Unless I buy some sort of Chevy someday.
looks like you're stuck... I guess you could plumb your intake direct. I've seen a few systems that go up under the intake...sneaky!
Re: 440 Six Pack Nitrous Install [Re: 340SHORTY] #1369136
01/27/13 06:28 AM
01/27/13 06:28 AM
Chicago
PurpleBeeper Offline OP
Chicago
Why is the switch hooked to the front carb instead of the center carb?
The full throttle switch is on the front carburetor because you should only use nitrous at wide-open-throttle and since the front/back carbs are vacuum seondaries basically they don't open up "immediately". Also, the nitrous plates are on the front/back carbs & only a spacer on the middle carb. I wanted to make sure all the carbs are open fully before the nitrous kicks in.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 440 Six Pack Nitrous Install [Re: Mr D21] #1369137
01/27/13 06:31 AM
01/27/13 06:31 AM
Chicago
Chicago
why doesnt the center carb get sprayed ?
I've wondered that myself, but that's the way Nitrous Oxide Systems built the kit. The center carb spacer does have holes drilled (and plugged) where you could put in another set of spray bars. It might be a clearance issue between the carburetors???
Re: 440 Six Pack Nitrous Install [Re: 6PKRTSE] #1369138
01/27/13 06:37 AM
01/27/13 06:37 AM
Chicago
Chicago
Looks cool. I have been wanting to ad to my sixpack car for quite awhile now. Only thing that has stopped me has been hood clearance issue on my Charger. I don't want to change from the factory hood. The sixpack air cleaner already rubs the hood pad.
It is hard to find the nitrous kit since discontinued from Holley.
Yeah, I forgot to mention that I had to clearance the air grabber scoop to clear the air cleaner.
Re: 440 Six Pack Nitrous Install [Re: Mr.Yuck] #1369139
01/27/13 08:49 AM
01/27/13 08:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
get one of these and you'll have no clearance issues...
Re: 440 Six Pack Nitrous Install [Re: PurpleBeeper] #1369140
01/27/13 08:56 AM
01/27/13 08:56 AM
Cincinnati, Ohio
Cincinnati, Ohio
Get the teflon tape off of the flare and compression fittings!! It should only be used on tapered pipe fittings.
With that much teflon wrapped around everything, I would not be surprised to see those fittings leak or worse yet get teflon inside your lines,soleniods and nozzles.
Flare and compression fittings can't be expected to seal with that junk wrapped around it. And by doing so on flare fittings it's almost a given that teflon is going to get inside your fittings. You can't keep it back like you must on tapered pipe fittings.
Plus it looks terrible to guys like me who know there way around fittings. Just trying to help you.
My work bench...couple months ago.
632 big chief pontiac on alky and nitrous injected with race gas controlled by one of the first micro processors, it pulsed the soleniods to keep from blowing off the tires. It had a ton of wiring also with diodes across every soleniod to protect the microprocessor. There was 10 soleniods.
Motor alone was over 1000HP I raced this around 1992-93.
Between the dry sump, mechanical alky injection the the N2O system, this car had I bet over 100 fuel and oil line fittings. I hand assembled this entire car, except I did not build the chassis, a friend from out of town did. I went a bunch of rounds and even won a race with this setup and always finished top 7 or better. One year I #1 quailified at every race, there 8 of them that year.
And there has been cars before and after that one.
Re: 440 Six Pack Nitrous Install [Re: Challenger 1] #1369141
01/27/13 10:03 AM
01/27/13 10:03 AM
Cincinnati, Ohio
Cincinnati, Ohio
I ran one of those plate systems on a brand new 87 ramcharger with a factory 360 with factory quadrajet carburator. It ran 14.00s with it with 33" tires and 4:11 gears. Quicker than the average mustang at the time. Drove the ramcharger to 90K miles and then sold it in 1993, took the N2O off first.
Picture of the ram in the background...no I never ran N2O on a bike, but I did race this. 9.0s at 139 Got my first sponsor on this bike.
Re: 440 Six Pack Nitrous Install [Re: Challenger 1] #1369142
01/27/13 12:22 PM
01/27/13 12:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah I guess i could have gone w/ a butt ugly 6-pack scoop or maybe a A-body Hemi scoop. or maybe a cooooo shaker??? nah they all look aweful on a Charger...
Re: 440 Six Pack Nitrous Install [Re: PurpleBeeper] #1369143
02/22/13 02:46 PM
02/22/13 02:46 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I just re-intalled the nitrous system (NOS Cheater) on my 1970 Road Runner 440 six pack & I thought everyone might like to see some pics. Enjoy!
I know that the six pack nitrous systems are no longer produced, but wonder if you might have an old part number for the entire system. I need to price one out, so maybe I'll be able to get some information with an old number.
This is the land of the free because of the brave
Re: 440 Six Pack Nitrous Install [Re: rbstroker] #1369144
02/23/13 11:25 AM
02/23/13 11:25 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I think the NOS part # was 02013 or something like that. Yes, it has deen discontinued for quite awhile now. It used to sell for around $600.00. I deal with Holley on a daily basis thru work & even tried to get them to just piece together the plates for me & then I would piece the rest of the kit together. They wouldn't even do that. They say they have no left over pieces. Wonder if we can spark enough interest we can get them to bring the kit back???
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 440 Six Pack Nitrous Install [Re: 6PKRTSE] #1369145
02/23/13 01:38 PM
02/23/13 01:38 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Thanks. I bought my system way back, when I lived in the Detroit area, from the old Ramchargers in Livonia. I just could not remember, for the life of me, what I paid for it. Now I have an idea of what to price it at when I go to the next swap meet. Thanks again.
Re: 440 Six Pack Nitrous Install [Re: rbstroker] #2720504
11/30/19 07:48 PM
11/30/19 07:48 PM
Louisiana
BiomedTechGuy Offline
Louisiana
I have a good reason for resurrecting this old thread.
I have a 6bbl 440, and I was interested in a Nitrous spray plate setup. I barely missed buying a gently used NOS 6bbl system, exactly the one described by Purple Beeper (whose car runs great, and PB is a great help on forums).
Nitrous Express makes a 6bbl Holley carbs compatible nitrous spray plate setup, but the CENTER carb is the one that would be sprayed, and the outboard carbs have the spacers.
I'm sure that you can get a 2nd spray plate and switch to the outboard carbs being the ones that get the juice, but be AWARE!
The outboard carbs on a vacuum actuated system, which is how the SB and BB Mopar 6bbl (and Tripower 427 Corvette) is made to work, HAS A LEAN A/F RATIO SPIKE for about one second when the outboard carbs open. Whether I use the spray plate on the center carb, or the outboard carbs, I would have a 1 second delay built in to be sure the nitrous doesn't spray during the lean tip in.
Re: 440 Six Pack Nitrous Install [Re: BiomedTechGuy] #2720564
12/01/19 06:54 AM
12/01/19 06:54 AM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
Good catch! And thanks for the heads up for any future users. I dreamed of having a Nitrous setup on my "440 to be" when I was a teen...
Re: 440 Six Pack Nitrous Install [Re: kowalski440] #2720566
12/01/19 07:27 AM
12/01/19 07:27 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
ooops, didnt see the post a coulpe above this.
Just an opinion that might save you some trouble, but id junk all but the plates and bend some nicer looking and more well routed SS lines and as well replace the noids with new units that, well that are simply new and more or less take care of a possible issue at the wrong time. You could live with small noids at your power level as well.
I still have the old holly paperwork for the kit in pdf I could post if anyone is interested.
Although cool its stone age tech, the plates, and its easy to buy the aluminum spacer plates off ebay and make your own with the more modern tips on the market. And ive found alot cheaper. Ive still that old kit on a ride and it adds to the cool factor and is great fun for just a bit more kick.
Have fun and be careful, you can only mess up one time and the funs over. Oh, Ive also found modern bottles, tank heaters, ele bottle opener can be had on CL dirt dirt cheap from the ricer boys who toast there setup in short order.
STOP POTATO HATE!
