Battery topper with right spacing- red caps?? #1369042
01/13/13 05:14 PM
01/13/13 05:14 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Red capped Mopar batteries mid sixties had a separation- three caps, then a space,then three more caps.. Topper I've seen has the red caps evenly spaced, same as the yellow and green toppers.. Anybody make a topper with the proper separation for a red cap battery ???
Re: Battery topper with right spacing- red caps?? [Re: gassy66] #1369043
01/13/13 09:05 PM
01/13/13 09:05 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I have'nt seen any...The toppers out there are'nt going to fool anyone to begin with...They'd be better off making a whole case sides and all... Then include a battery hold-down that will span the wider case...That's the biggest downfall with those toppers, most the original style clamp assemblys are'nt wide enough to span over them..
