Re: new Holley 6 bbl carbs...wrong float bowl screws??
[Re: RPM Motorsports]
#1368862
01/13/13 12:02 PM
01/13/13 12:02 PM
Posts: 4,872 connecticut
pnypwr
connecticut
any old holley would work for the bowl screws...theyre correct in fit and function, prob not to concerned with hardware, you cant see the bowl screws with the air cleaner on anyways
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
#1368868
01/13/13 01:02 PM
01/13/13 01:02 PM
Posts: 21,448 It's a dry heat
gtx6970
It's a dry heat
There is 2 different length screws for the float bowls in those kits??
correct, center carb takes a slightly longer one.
[Re: gtx6970]
#1368870
01/13/13 03:17 PM
01/13/13 03:17 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
i have always had problems torquing the screws to the correct torque. I was enthralled when Holley went to hex head capscrews.
[Re: floyd]
#1368872
01/13/13 04:45 PM
01/13/13 04:45 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The stamped List & Chrysler part numbers on the reissues six-pack carbs represent original design specifications for their original applications only. They will contain minor Holley overall production changes that have occurred in the years since the original carbs went out of production as long as they don’t alter the design specs as they pertain to functionality. Holley went to hex head fuel bowl screws many years ago. More than likely to improve the process of setting even fuel bowl screw torque specifications on a mounted carb. It was a pain in the rear with slotted screw heads. Mine also had contained the newer gasket materials and the later blow-out resistant power valve. Date code should be reflective of the actual production date of the reissue. Carb pictured below was purchased new around ’07. Note the Torx headed screw securing the bowl vent lever rod, pretty sure that was a Phillips head screw originally.
Correct on all accounts. These are the differences that restoration minded owners need to be aware of when deciding on which way to go, buy new carbs or restore what they have, there are a bunch of small differences between vintage Holley's vs new when it comes to details, screws, misc. hardware, the Holley script on the bowls, plating and dip color, all kinds of stuff.
[Re: 72roadrunnergtx]
#1368874
01/15/13 12:31 AM
01/15/13 12:31 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
As for the bowl vent screw I've seen both Phillips and slotted Fillister head on original carbs.
[Re: Fabman]
#1368876
04/01/13 10:41 PM
04/01/13 10:41 PM
62maxwgn
Blair County,PA
I dont mean to steal this thread...BUT...I am looking for a replacement fuel bowl for the rear carb on my 6 pack set up...Its a 340 T/A - Carb number is a R4970A. The one thats on the car now is wrong...It has the accelerator pump holes epoxied shut....and now its starting to drip......
Thanks !
Carb number makes no difference,front and rear big block and small block are all the same.
[Re: 62maxwgn]
#1368877
04/02/13 08:18 AM
04/02/13 08:18 AM
Posts: 2,634 Right Coast
Fabman
Right Coast
Thanks !
Great ! Good info....now...anyone know where I can get one???
[Re: Fabman]
#1368879
04/02/13 12:14 PM
04/02/13 12:14 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Thanks !
Did you try Holley ? last time I checked they sell parts also.
[Re: JohnRR]
#1368880
04/02/13 12:34 PM
04/02/13 12:34 PM
62maxwgn
Blair County,PA
Thanks !
John,only thing wrong with Holley is the price !! Out of these three sets,there were five bad bowl's,three had stripped needle /seat threads which I fixed,the other were Chevy bowls which I replaced,the two I bought from Chicago Corvette cost me less than $60. for both .
