Hemi heads #1368372
01/12/13 07:03 AM
01/12/13 07:03 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Which would you buy? With a budget being an issue, stock 426 hemi heads ready to go or for $500 more get some new Mopar Performance heads. Either way I have to buy them. Are the new ones better being the stock ones are known to crack in the plug to valve area. Thanks
Re: Hemi heads [Re: maximus] #1368373
01/12/13 08:12 AM
01/12/13 08:12 AM
tboomer Offline
tboomer  Offline
I would ask Bob George...He can fix ya up!
Re: Hemi heads [Re: maximus] #1368374
01/12/13 01:18 PM
01/12/13 01:18 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I've had lots of used heads aluminum and iron, got lucky a few times but ended up with junk a few times too. My last two builds I just bought new Stage V replacement heads, you're money ahead with new heads and the Stage V is a great quality casting that looks original as well.
Sheldon
Re: Hemi heads [Re: RUNCHARGER] #1368375
01/12/13 01:43 PM
01/12/13 01:43 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Sheldon
couldnt have said it better myself
Re: Hemi heads [Re: prochargedhemi] #1368376
01/12/13 04:53 PM
01/12/13 04:53 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Thats what I did!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hemi heads [Re: maximus] #1368377
01/12/13 05:11 PM
01/12/13 05:11 PM
MN
hemidup Offline
hemidup  Offline
MN
Finally giving up the old K heads and going with the Stage V's... Painted Race Hemi orange of course.
Jerry Williams.
Re: Hemi heads [Re: RUNCHARGER] #1368378
01/12/13 06:16 PM
01/12/13 06:16 PM
Sheldon
Some things you need to buy new especially on Hemi motors
Re: Hemi heads [Re: Cab_Burge] #1368379
01/12/13 09:13 PM
01/12/13 09:13 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
yep
Re: Hemi heads [Re: VanishPt] #1368380
01/14/13 11:49 AM
01/14/13 11:49 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The problem is money. I feel the Stage V's are the best but by the time you complete the ports, valve job etc. the price is higher. If budget is an issue for you complete mopar heads would be cheaper.
2011 Drag Pak Challenger
Re: Hemi heads [Re: rickseeman] #1368381
01/14/13 04:26 PM
01/14/13 04:26 PM
Stage V will sell you, or they use to, a set of heads ready to bolt on as long as you tell them which type of cam and the lift your going to run Thier heads are GREAT
Re: Hemi heads [Re: Cab_Burge] #1368382
01/14/13 04:59 PM
01/14/13 04:59 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The Stage Vs are a quality head but if your on a budget the Indy 426-SR for under $2000 and the 426-HiPo for under $2500 are great buys.
Re: Hemi heads [Re: hemidup] #1368383
01/15/13 01:22 PM
01/15/13 01:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Wouldn't it be nice if Stage V would cast some new 65 heads? His castings are so beautiful.
