Re: is anyone running a 28inch tall tire on a 17inch rim?
[Re: 70BigBlockSE]
#1367740
01/15/13 11:14 PM
01/15/13 11:14 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Mag 500 17"...28" tall tire. Eagle RS-A 235/55 up front...255/55 on the rear. I could have put 275s if I had an extra inch on the backspacing but they were a custom order and it would have been dangerously close to my leaf spring
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Fishmarket]
#1367742
01/20/13 06:58 PM
01/20/13 06:58 PM
Posts: 9,404 Texas
carcrazyguy
Texas
Fishmarket... Are you looking for your 71 B-body? Curious because I am shopping for tires for my 71 Charger. Since I want matching brand/tread on front and back I was leaning towards.... Nitto 450's 255/50/17 front on 17x8 (27.05 overall height) 4 1/2" backspace 275/50/17 rear on 17x9 (27.83 overall height) 5" backspace puts it somewhat close to what a lot of people are running (height) in 15" tires. 235/60/15 front 26.10 275/60/15 rear 27.99 I figured the extra 1" height in the front would help with the "level" look. However I am NO expert! The main thing that worries me is putting such a wide tread on the front. Wonder how that is going to drive???
[Re: carcrazyguy]
#1367743
01/20/13 08:03 PM
01/20/13 08:03 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I bet you could run a 275/40/17 (25.75") in the front with 17x9 with 5" backspacing.
Might even be interesting to buy your rear tires and rims first. Then just put them on the front to see if they would fit.
[Re: carcrazyguy]
#1367749
01/21/13 01:27 PM
01/21/13 01:27 PM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Any side shots? I know the 71 B-bodies have a larger wheel opening...but would still like to see the side profile.
Here's the side view, and yes, it is a 27" tire, not 28".
[Re: 1st_charger]
#1367752
01/21/13 11:30 PM
01/21/13 11:30 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I am running a M&H drag radial 325/45/r17 http://www.summitracing.com/parts/mnh-rod20It is the biggest 17 tire u will find they say min 11" rim in the summit catalog is BS i run it on 9.5 fits perfect .
1969 Dodge Charger
1969 Dodge Superbee
[Re: Pyper70]
#1367753
01/26/13 12:13 PM
01/26/13 12:13 PM
Posts: 677 Southeastern Ohio
1st_charger
Southeastern Ohio
Pyper where did you get your 255/55 17 Eagle RS-A tires I cant find them listed on goodyears site I have only found used on ebay?????
Thanks again everyone!
