Re: Pin on 'glass on the street? [Re: Chris2581] #1366714
01/08/13 11:23 PM
01/08/13 11:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
mines a "race weight" pin on. no problems.
Coming soon!!!!
Re: Pin on 'glass on the street? [Re: thedriver] #1366715
01/08/13 11:53 PM
01/08/13 11:53 PM
I'm looking to get a glass hood for my challenger. Six pack hood. Mostly cuz I love the look, also because my rallye hood weighs a ton.
When I finish the car this time it will be raced less, highway driven more.
I don't do shows, and I'm not anal about my clean engine bay, so i won't show that off.
Mostly curious at what speed does the hood start to do funny things, and how many pins to use?
I'm going to assume that when you say six pak hood your talking about the 1969 six pak scoop on a 1970 Challenger hood, not the fibreglas 1970 T/A sixpak hood and scoop. I bought a raceweight Duster hood with a 1968 Hemi scoop molded on it by the fibreglass company I bought it from, I did what Doc Fibregals is suggesting, I molded some aluminum angle brackets onto the bottom of the hood so it would bolt onto the stock A body hinges. I removed the stock hood springs and use a broom stick to hold the hood up when open, trying to mislead some of those that think they have a "fast car" I used two Dzuz fateners behind the scoop, the two stock hinges at the rear corners, two more dzuz fasteners between te hinges and the front and four more dzuz aster acros the front. The scoop stays normal until around 125 + MPH, the faster the car goes the taller the scoop try to stretch It runs 134.+ MPH in the 1/4 now I use to have a sixpak on the motor and I trimmed the hood so the stock type six pak aircleaner elements with two stacked on top of each other would clear the hood that meant it has two bolts holding the front of the scoop on the front instead of four like the 1968 SS cars have Several of my other bracket cars had lift off hoods, I hated them, especially at the track when the wind was blowing
Re: Pin on 'glass on the street? [Re: Cab_Burge] #1366716
01/09/13 12:48 AM
01/09/13 12:48 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have a glass hood on my 63. I have foam under it so on nice days I can sit the hood on the roof. But if its windy at all the hood stays on. I like it the best when I have to work on the car as it gives plenty of light to see real good and dont have to worry about hitting my head on the safety catch. Ron
Re: Pin on 'glass on the street? [Re: 383man] #1366717
01/09/13 12:56 AM
01/09/13 12:56 AM
Outside
thedriver Offline OP
Outside
Cool, thanks guys. Can't post pic from my not so smart phone. Im thinking of a 4" six pack like the one on that red hemi challenger mr norm did.
1973 challenger
Dana. 4 speed. Low deck.
Re: Pin on 'glass on the street? [Re: dOc …] #1366718
01/09/13 12:56 AM
01/09/13 12:56 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Come on guys ....at the shows you can make those 2-3 foot pin extensions. ALSO .. you can adapt a totally PIN ON hood to "bolt-on" to the hinges ...IF the bracing is done decently.
We (the car owner actually) just fabbed some aluminum structure to bolt his lift off hood to a hinged deal. Came out pretty slick for minmal dough and time.
I have a bolt on AAR 6-pack hood for my Dart project and it is a NICE piece. No, it's not the max weight savings but it is WAY lighter than my OE steel flat hood is!
Guess it depends on how "race car" you need your street car to be. I'll never have a pin on hood on a street car again (had 2) but that's just me.
What difference is a pin on hood REALLY going to show on a timeslip compared to a bolt on? Not very much...
Re: Pin on 'glass on the street? [Re: cudadoug] #1366719
01/09/13 01:33 PM
01/09/13 01:33 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
for my hemi dart clone i didn't want to worry about the scratches or wind so i sloted the back hood pin bezels and made aluminum sleeves and bent 2 hood pins + made a prop rod for the front so i can show the engine at cruises with out the worries. seems the engine is what always grabs their attention lol. the sleeves and bent pins tend to stabilize the rear of the hood in case it gets bumped or slightly windy. if i think it's too windy i put the hood down dave
Re: Pin on 'glass on the street? [Re: 3ddart] #1366720
01/09/13 01:36 PM
01/09/13 01:36 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
closer picture.
Re: Pin on 'glass on the street? [Re: 3ddart] #1366721
01/09/13 02:45 PM
01/09/13 02:45 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
My dad and I both just carried in the car a small blanket or the car covers and just put them on the roof to protect it.
Re: Pin on 'glass on the street? [Re: thedriver] #1366722
01/09/13 02:54 PM
01/09/13 02:54 PM
NY usa
540challenger Offline
NY usa
Just becareful when the hood is off, One windy day on an open field
and it could take flight
Re: Pin on 'glass on the street? [Re: 540challenger] #1366723
01/09/13 05:11 PM
01/09/13 05:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My buddy has this 6pk lift off hood on his Demon and I think its the 4" one like you plan to use. Ron
Re: Pin on 'glass on the street? [Re: 383man] #1366724
01/09/13 05:22 PM
01/09/13 05:22 PM
Outside
Outside
Perfect.
1973 challenger
Re: Pin on 'glass on the street? [Re: thedriver] #1366725
01/09/13 06:25 PM
01/09/13 06:25 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I had a lift off hood on my cuda for a while, didn't care for the hassle so I replaced it w/ a bolt on and love it. Lift offs are great for working on the car and for weight savings. It's easier to fab an air pan setup to seal your carb to the hood w/ a lift off hood too.
If it's windy it will fly off the roof and may or may not take some paint w/ it. If it's rigid enough not to need 30 hood pins or dzus clips to hold it on, it'll probably be heavy and a pain to handle by yourself. Dzus clips are a PITA and you'll probably wind up scratching your the car when the tool you use to release them slips off the clip and gouges your paint.
I like my bolt on.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pin on 'glass on the street? [Re: Mr.Yuck] #1366726
01/09/13 06:30 PM
01/09/13 06:30 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I have a bolt on AAR 6 pack hood that is a pin on hood now. I don't mind it not bad at all to pull off yourself, I would rather have the room.
Mopar Performance
Re: Pin on 'glass on the street? [Re: moparniac] #1366727
01/09/13 06:38 PM
01/09/13 06:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like my idea of having both worlds... a pin on
but also using the hinges... just a matter of mounting
a bracket to each side of the hood.... I was working
on mine today
Re: Pin on 'glass on the street? [Re: an8sec70cuda] #1366728
01/09/13 06:46 PM
01/09/13 06:46 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
mine is a bolt on and its standard weight but I moved the pins in some on each side and welded brackets to the firewall and it;s pretty sturdy... Take it off myself no problem.
Mopar Performance
Re: Pin on 'glass on the street? [Re: moparniac] #1366729
01/10/13 01:21 AM
01/10/13 01:21 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have a pin on and it moves around to much to wear it.Nowadays it will only go on when I go to Carlisle.Hardly ever get asked if I even have one
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Pin on 'glass on the street? [Re: hemi-itis] #1366730
01/10/13 11:11 AM
01/10/13 11:11 AM
Tampa Florida
ProStreetFm3 Offline
Tampa Florida
Had one on since 89 I guess I got used to it .. And it gives the girl something to hold on to for pic
