Pin on 'glass on the street? #1366694
01/08/13 08:03 PM
01/08/13 08:03 PM
Outside
thedriver Offline OP
Outside
Who runs a light weight pin on hood on the street/highway?
Is it a pain? Or totally fine. Don't need pros as much as cons!
Thanks!
1973 challenger
Dana. 4 speed. Low deck.
Re: Pin on 'glass on the street? [Re: thedriver] #1366695
01/08/13 08:08 PM
01/08/13 08:08 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Thanks!
It's generally only a "con" if you have to open it in a confined space without any place to set the hood down. If the underside has foam - you can set it on the roof - if it's not windy.
Re: Pin on 'glass on the street? [Re: Duner] #1366696
01/08/13 08:19 PM
01/08/13 08:19 PM
Guitar Jones Offline
Thanks!
That about says it all.
Re: Pin on 'glass on the street? [Re: Duner] #1366697
01/08/13 08:19 PM
01/08/13 08:19 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I have ran a pin on or dzus fasteners hood for years. I ran it on the street. It sucks. Cruise in's are a pain to take the hood and put it somewhere if you want to show off your engine.
But, that said how much weight you trying to loose as a bolt on is a joke for weight savings. It just depends on how bad you want to go faster. I will go through the pains to be faster.
Leon
Re: Pin on 'glass on the street? [Re: Leon441] #1366698
01/08/13 08:27 PM
01/08/13 08:27 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Frankly, it's a pain in the butt even on my racecar; some day soon I'll put hinges and the steel hood back on it.
Re: Pin on 'glass on the street? [Re: topside] #1366699
01/08/13 08:38 PM
01/08/13 08:38 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Pin-On here. I put it on the roof when I need it off I dont bother laying down a blanket or anything first either. Then again, im not worried about my beater being scratched...
Opinions may vary.
Re: Pin on 'glass on the street? [Re: 69B3GT] #1366700
01/08/13 08:47 PM
01/08/13 08:47 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Come on guys ....at the shows you can make those 2-3 foot pin extensions. ALSO .. you can adapt a totally PIN ON hood to "bolt-on" to the hinges ...IF the bracing is done decently.
Re: Pin on 'glass on the street? [Re: dOc !] #1366701
01/08/13 08:55 PM
01/08/13 08:55 PM
Outside
Outside
I'm looking to get a glass hood for my challenger. Six pack hood. Mostly cuz I love the look, also because my rallye hood weighs a ton.
When I finish the car this time it will be raced less, highway driven more.
I don't do shows, and I'm not anal about my clean engine bay, so i won't show that off.
Mostly curious at what speed does the hood start to do funny things, and how many pins to use?
1973 challenger
Re: Pin on 'glass on the street? [Re: thedriver] #1366702
01/08/13 09:01 PM
01/08/13 09:01 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My Demon has a pin on hood,and is going to see street duty this spring.All I do at the track is put the hood on the roof(it has soft foam on the underside) BUT I did have a wind gust come thru at the track one time and the hood blew off the roof.I have 6 pins on the hood (3 in front,3 in back) and the only time it starts moving around is on the top end.
Now make sure that you pin the hood before you drive...even at slow speeds..it WILL come off..I forgot to pin it after going thru tech..off it went.
Nautilus Racing-
Re: Pin on 'glass on the street? [Re: thedriver] #1366703
01/08/13 09:07 PM
01/08/13 09:07 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
......................and how many pins to use?
Depends on how good the bracing is. I have built hoods with thin-wall steel tubing, alum and even mag tubing !
Re: Pin on 'glass on the street? [Re: dOc !] #1366704
01/08/13 09:13 PM
01/08/13 09:13 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
My brother has a pin on, hates it, would already be gone if we thought we could do it without mismatched paint
Re: Pin on 'glass on the street? [Re: thedriver] #1366705
01/08/13 09:17 PM
01/08/13 09:17 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I've had a pin on hood on my Satellite for 15+ years. With a six pak scoop, the hood is easy to remove and install by myself. One hand on the front of the hood and the other hand in the scoop opening. The stock hood and hinges weighed about 67 lbs. My 'glass hood weighs about 20 lbs.
Re: Pin on 'glass on the street? [Re: SpareParts] #1366706
01/08/13 09:22 PM
01/08/13 09:22 PM
Outside
Outside
Please expand on why your brother hates his?
The car is gonna go fast at times. Still don't know what motor to build, but since it's a highway car with Od, it will go as fast as parts like the hood will let me!
1973 challenger
Re: Pin on 'glass on the street? [Re: dOc !] #1366707
01/08/13 09:25 PM
01/08/13 09:25 PM
Indianapolis
Roadrunner451 Offline
Indianapolis
As Doc says, you can get one ready to bolt to the stock hinges. I think I got mine from Unlimited. It needed a bit of work, but it bolted to the stock hinges without a problem. You need to use lightweight hood springs though. When it is setup like that it isn't any different than a stock hood. And when I needed to remove mine this last time to pull the motor, I removed the hood from the car by myself. Try that with a steel hood.
Re: Pin on 'glass on the street? [Re: thedriver] #1366708
01/08/13 09:27 PM
01/08/13 09:27 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My blue DartSport had a lift off hood and it got old sometimes, especially on windy days at the track or at a car show.
My Purple 69 Dart had a hinged hood and it was always in the way while wrenching.
So it's a toss-up for me.
Re: Pin on 'glass on the street? [Re: Roadrunner451] #1366709
01/08/13 09:29 PM
01/08/13 09:29 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Rr .... you don't need to buy one that has that OEM type underhood bracing ... you can adapt the two brackets TO the race-type bracing ... IF it positioned in a decent location.
Re: Pin on 'glass on the street? [Re: thedriver] #1366710
01/08/13 09:34 PM
01/08/13 09:34 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have a Demon, lift off hood, had a hemi dart hoodscoop on it, and it wanted to rip the hood off at 120mph. Changed it out to a snorkel type and it stays put at 130mph, with 6 pins, 3 in the front and 3 in the back. I say go for it, I don't think it is that big a deal. I would think you would know not to take it off in the wind, unlike the chevy guys.
Re: Pin on 'glass on the street? [Re: Dodgeguy101] #1366711
01/08/13 09:39 PM
01/08/13 09:39 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Love it hate it. Love to work on it with no hood, hate it when you want to show a buddy your motor. I would not change it though. Going on 15 yrs with it. You want 4 or 5 Zeus fasteners across the front if your going fast.(150 mph)
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Pin on 'glass on the street? [Re: 1967dartgt] #1366712
01/08/13 09:56 PM
01/08/13 09:56 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ive been running one for about 11 years. If someone wants to see my engine they help take it off.
Mopar to the bone!!!
Re: Pin on 'glass on the street? [Re: thedriver] #1366713
01/08/13 10:00 PM
01/08/13 10:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a pin on hood with cowl scoop but I am looking
to make it a hinged type BUT with a slide on hinge
and it will still have 4 pins(sorta fancy ones) in
the link.. I dont have springs so I use a prop rod..
so if I want I can slide it off the hinges and set
it off to the side or use the stanchions like Doc said
http://www.deftracing.com/aerocatch_hood_pins/aerocatch_plus_flush_hood_latches.htm
