Re: Downshift kickdown 727. [Re: John_Kunkel] #1366290
01/09/13 05:57 PM
01/09/13 05:57 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I have thought about manually dropping it from 3-2 but never had the guts to do it at a WOT stab in the fear that it would rev too high too quick. This is why I was looking to be able to modify the auto kick-down feature to keep it safe.
Re: Downshift kickdown 727. [Re: YO7_A66] #1366291
01/09/13 06:25 PM
01/09/13 06:25 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
May be if we use the 426 governor and the 3.23 axle ratio you can have 3 to 2 downshift from 70 to 84 mph as per the shop manual.
Will be our target...
Re: Downshift kickdown 727. [Re: 383man] #1366292
01/09/13 06:31 PM
01/09/13 06:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
John might know what trannys have a "limit valve".
The limit valve is for PTK only on the '71 and later.
What limits WOT 3-2 kickdown is the combination of axle ratio and governor.
Re: Downshift kickdown 727. [Re: STROKIE] #1366293
01/09/13 07:27 PM
01/09/13 07:27 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My problem is that I want to keep my 3:91's, so I will have to do something with the governor assembly. I have already emailed A&A to see what my governor options might be for this.
Note: My valve body has been upgraded with the 71 & later PTK.
Re: Downshift kickdown 727. [Re: YO7_A66] #1366294
01/10/13 03:21 PM
01/10/13 03:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the '71-later PTK module is installed on a pre-'71 VB the limit valve won't function.
Re: Downshift kickdown 727. [Re: John_Kunkel] #1366295
01/10/13 03:39 PM
01/10/13 03:39 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I should have wrote that my valve body is a 71 or later model with the PTK.
Re: Downshift kickdown 727. [Re: STROKIE] #1366296
01/10/13 07:57 PM
01/10/13 07:57 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
I would like to know how Chrysler can downshift the Torqueflite 727 3-2 downshift with 3.23 axle ratio from 70-84mph (I prefer 84 mph.) many Moparts fan will be happy.
John kunkel may know...
Re: Downshift kickdown 727. [Re: STROKIE] #1366297
01/10/13 08:14 PM
01/10/13 08:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Once again, it's all about the governor and the axle ratio.
A trans with a Hemi governor and and 3.91 gears might not 3-2 kickdown above 70 mph while the exact same trans with 3.23's might still kickdown at 84 mph. The governor only knows the rpm of the output shaft, not the road speed of the car.
84 mph in 2nd gear with 3.23 gears is around 5000 engine rpm, within the limits of the Hemi governor.
Re: Downshift kickdown 727. [Re: John_Kunkel] #1366298
01/11/13 10:19 AM
01/11/13 10:19 AM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
A&A transmissions sell many Governor Kits from 5000 to 6000+ rpm...
They have 2 different Hemi governor kit 5400 & 5600 rpm.
As per shop manual Wide Open Throttle 2-3 Upshift with 3.23 Axle Ratio can be at 93 Mph must equal to around 5800 rpm.
Logically I must order the 5800 Rpm Max Wedge governor kit to upshit at 93 mph and kickdown at 3-2 kickdown at 84 mph.
Re: Downshift kickdown 727. [Re: STROKIE] #1366299
01/11/13 05:45 PM
01/11/13 05:45 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Might tire size account for the ranges that are given on MPH with the various gear sets?
I want my fair share
Re: Downshift kickdown 727. [Re: SomeCarGuy] #1366300
01/11/13 07:50 PM
01/11/13 07:50 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
As per shop manual Wide Open Throttle 2-3 Upshift with 3.23 Axle WITH 26 INCHES TIRES. Ratio can be at 93 Mph must equal to around 5800 rpm.
Re: Downshift kickdown 727. [Re: STROKIE] #1366301
01/11/13 08:41 PM
01/11/13 08:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Hemi cars traditionally had 15" tires which were closer to 27" in diameter.
Re: Downshift kickdown 727. [Re: John_Kunkel] #1366302
01/12/13 10:29 AM
01/12/13 10:29 AM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
My car is a Dodge Charger 1967 as per the shop manual Hemi cars are fitted with 7.75-14 can be close to 27" in diameter.
