The transmission has no idea what the road speed is, it only knows output shaft speed. So the forced downshift lockout road speed will vary greatly with the axle ratio.
The chart below shows the relationship of axle ratio and governors....note the difference in 3-2 forced downshift speed with the same gears but different governors.
As will different gearing change shift points using the same governor.
