flex plate shield clearance help #1365949
01/07/13 02:19 PM
01/07/13 02:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have more than 1" that hits the stock firewall as marked on the tape and I cant move the engine enough down or forward to make it not hit the firewall.
Re: flex plate shield clearance help [Re: Clanton] #1365950
01/07/13 02:35 PM
01/07/13 02:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
other pics
Re: flex plate shield clearance help [Re: Clanton] #1365951
01/07/13 02:36 PM
01/07/13 02:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
3
Re: flex plate shield clearance help [Re: Clanton] #1365952
01/07/13 02:45 PM
01/07/13 02:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well if you are going to run that type you will need to cut the firewall. If you dont wanna do that then go with a CSR one piece one. You will still need to massage the tunnel a bot but wont have to remove any part of the firewall.
Re: flex plate shield clearance help [Re: Clanton] #1365953
01/07/13 04:06 PM
01/07/13 04:06 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
sometimes the SFI inspector will let you mod a product and still let it pass.My idea is if i use an alan bolt and bend the shield to clear the firewall flat on the trans in that area I can drill a hole for the alan to tighten the bolt in those 2 places.
Re: flex plate shield clearance help [Re: Clanton] #1365954
01/07/13 08:52 PM
01/07/13 08:52 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yea there no way I could put one of them on my car. and the one piece carbon shield would be hard. I thought if I had to run one. I might do one of them aftermarket bell housing.
Re: flex plate shield clearance help [Re: VernMotor] #1365955
01/07/13 09:16 PM
01/07/13 09:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I know an ultra bell would make it easier but cost much more so in my own hard headed ways I have to try.I measured some more on my mockup trans and if I bend at the lines in a 45* or more it will fit but need the hole for the bolt that would be impossable to see in the car.
Re: flex plate shield clearance help [Re: Clanton] #1365956
01/07/13 09:38 PM
01/07/13 09:38 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Why do you NEED a flex plate shield?? I thought that was for the Chebby guys.
If you like drag racing, support your local track.
Re: flex plate shield clearance help [Re: CHAPPER] #1365957
01/07/13 10:07 PM
01/07/13 10:07 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
9.99 faster needs a shield unless you have an sfi bell.or something like that.
Re: flex plate shield clearance help [Re: Clanton] #1365958
01/07/13 10:31 PM
01/07/13 10:31 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
With no ring gear for the starter on the flex plate of a Mopar,,,I don't see the need. I guess rules are rules though if you want to race NHRA.
Re: flex plate shield clearance help [Re: CHAPPER] #1365959
01/07/13 11:05 PM
01/07/13 11:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
IHRA also!
Re: flex plate shield clearance help [Re: Clanton] #1365960
01/07/13 11:27 PM
01/07/13 11:27 PM
Renton Washington
Triple Threat Offline
Renton Washington
I would personally just run the CSR shield instead of that and a blanket.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: flex plate shield clearance help [Re: Clanton] #1365961
01/08/13 12:03 AM
01/08/13 12:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mike,I got one of those 15 years ago.Looks good on the shelf,Get the CSR sheild and be done
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: flex plate shield clearance help [Re: hemi-itis] #1365962
01/08/13 12:16 AM
01/08/13 12:16 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
NO!I won't be discouraged yet.
Re: flex plate shield clearance help [Re: Clanton] #1365963
01/08/13 01:24 AM
01/08/13 01:24 AM
hemi-itis Offline
hemi-itis  Offline
You will have to HACK the tunnel to make it fit and you STill need a blanket.Can you return that for credit?????????
Re: flex plate shield clearance help [Re: Al_Alguire] #1365964
01/08/13 02:33 AM
01/08/13 02:33 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Those shields aren't ment to be installed on a stock bodied car, they fit best on chassis cars or dragsters where they can be added to the car as part of the original build plan, you'll have to butcher the car to get it to fit
Re: flex plate shield clearance help [Re: formula S] #1365965
01/08/13 04:20 AM
01/08/13 04:20 AM
Oh
His and Her 69's Offline
Oh
I had the CSR full shield on the woman's car and it hit the seam where the firewall and tunnel are spot welded together. If you bend the flanges flat to the floorpan it will clear good. I got it to work without bending it but then the shifter cable was getting smashed and it shifted hard.
I finally on the last rebuild took off the shield and installed a blanket. Fits Great, shifts Great, works for tech, and all is Good.
Sorry I can't help you on that flywheel shield though.
Maybe it is hitting the flanges like mine did.
David
Re: flex plate shield clearance help [Re: His and Her 69's] #1365966
01/08/13 07:20 AM
01/08/13 07:20 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Make the tunnel bigger, you'll be happy you did. Easier to get the trans out.
Doug
Re: flex plate shield clearance help [Re: dvw] #1365967
01/08/13 11:31 AM
01/08/13 11:31 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for all the info on the CSR but I would rather use an ultra bell and a blanket before that.I would assume that none of you have tried to mod the flexplate shield to see if tech would pass it but speekup if you have,I can't be the 1st 1 to try!
Re: flex plate shield clearance help [Re: dvw] #1365968
01/08/13 11:38 AM
01/08/13 11:38 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Cutting or trimming your shield invalidates the SFI certification – Hence nobody will pass it in real tech inspection (divisional or national meet). Local track inspection maybe – being that they use the better than nothing rule! - You seem to want to re-invent the wheel – the CSR Kevlar shield is a much better way to go and a whole lot safer in the long run – it should fit with a little BFH finesse on the body seam lip in the trans tunnel – Blankets and clunky shields are things of the past since the Kevlar shield came out. Just ask anybody who has exploded a T-Flight and had a kevlar shield to contain it.
