Big inch Hemi guys - which SFI flexplate?
#1365784
01/07/13 09:16 AM
01/07/13 09:16 AM
Posts: 625 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
572 hemi with 727 and 9" Ultimate vertor. Which flexplate/part # do you guys run? Thanx...
Re: Big inch Hemi guys - which SFI flexplate?
[Re: Dyno1]
#1365789
01/08/13 08:28 AM
01/08/13 08:28 AM
Posts: 1,629 pa
572charger
pa
B+M on mine, red loctite and let it sit over night before running it !!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Dragula]
#1365791
01/08/13 09:02 AM
01/08/13 09:02 AM
LAD 524
Deep DEEP SOUTH
Hmmm, thnx guys it looks like the B&M unit is suspect. Other than Mancini, who else can this MP plate be sourced from? Also an aside - does anyone know the correct ARP part numbers for the 8 bolt Hemi flexplate bolts and the correct convertor bolts for a 9" Ultimate convertor? Is there a std size/length? Thanx !
[Re: 572charger]
#1365792
01/08/13 10:38 AM
01/08/13 10:38 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Never had a problem w/ B&M plates.
[Re: an8sec70cuda]
#1365793
01/08/13 01:00 PM
01/08/13 01:00 PM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I have 4 B&M flexplates that cracked by the converter holes, over a 2 year period. Switched to the Mopar flexplate, and no more cracks. There is more meat around the converter bolt holes on the Mopar flexplate. Always used Red loctite. Mine is only a 505 cubic inch wedge, 8 bolt Callies crank.....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
