64 valiant
#1365718
01/07/13 12:41 AM
01/07/13 12:41 AM
Posts: 5,160 Texas
dannysbee
Texas
What does it take to get a 275-60-15 on a 64 valiant?
Getting old just means you were smarter than some and luckier than others.
Re: 64 valiant
[Re: SB449VALIANT]
#1365723
01/07/13 09:26 AM
01/07/13 09:26 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Seems like a Dart to me, and with a modified wheel opening. But basically you have to move the springs to the framerails and minitube it. With the sotck wheelwells and spring position, 245 wide is about max.
Plynouth VIP '67 TT IC EFI
Re: 64 valiant
[Re: dannysbee]
#1365724
01/07/13 12:07 PM
01/07/13 12:07 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
A few years ago, I was able to get a 245/60/15 street tire on a '65 Valiant with no modifications to the wheel wells or spring location. I put new leaf springs in though and had them arched 2" over stock to get clearance. They settled some and looked OK. I used a 15 x 8 wheel with 4.875" backspace. No rubbing at all.
You could possibly get it done with the offset spring hanger but a mini tub would probably be best. One issue you might run into though is the height of the tire. The outside top edge can rub the inside wheel well above where the lip is. You can push it out a little with a bottle jack or a BFH if needed.
There are a few early Valiant NHRA stockers running 255/60/15 drag radials with everything in the stock locations. Tight but it fits.
'71 Duster '17 Ram 1500
Re: 64 valiant
[Re: RMCHRGR]
#1365725
01/07/13 03:16 PM
01/07/13 03:16 PM
Posts: 614 ont,canada
mopartuner
ont,canada
My 65 barracuda has 275's on it and all I had to do was move the springs under the rail and push the floorpan/trunk/wheel tub ext over to be flush with the frame rail.I use a 15x7 wheel with a 4-3/4 neg offset.I actually have plenty of clearance.
410 pump gas solis flat tappet cam 10.95 so far
Re: 64 valiant
[Re: JBurch]
#1365727
01/07/13 05:44 PM
01/07/13 05:44 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
265X55X15 BFG in stock wheeltubs and stock suspension. Rubbed a little while cornering hard. -65 Valiant
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: 64 valiant
[Re: fed]
#1365728
01/07/13 08:13 PM
01/07/13 08:13 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Never tried that exact tire.
The quarter panel pictured is of a 65 Dart. I have made that wheel opening. Recognize the body line. Valaint and Barracuda do not have the body line over the wheel for information. But, as far as fitting tires they are the same other than the lip sits a little further in on the dart.
I know a N50-15 will fit with an inboard spring kit and mini tubs with no cutting of the quarter and a 15X9 centerline with 7.25' back spacing. The 275/60/15 is the same as a L60. Less backspacing and should not have to minitub. But, the leafs need some moving. Sorry I just not 100% sure on what has to be done for that specific size. A G60 will fit with no work at all.
Leon
Re: 64 valiant
[Re: Leon441]
#1365729
01/07/13 08:54 PM
01/07/13 08:54 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I have a 65 moved the springs in and cut the tubs and moved them in plenty of room now, i pick up over 4 inches. i have pics if you need them
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
Re: 64 valiant
[Re: 65signet]
#1365730
01/07/13 09:37 PM
01/07/13 09:37 PM
Posts: 34,912 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Yes, because I am building a 65 Val wagon and want to stuff some of them under it too
Re: 64 valiant
[Re: dannysbee]
#1365735
01/11/13 01:42 AM
01/11/13 01:42 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Friend of mine runs 275 50 15 drag radials on a stock bodied 67 coronet with cop car wheels.
I cant think of worse cars for tire clearance than a 67 coronet. The 275 50 15 is the same width as a 275 60 15 just lower. Might give you what your looking for.
