B- Body repro door handles - buttons rattle constantly #1363761
01/03/13 12:47 PM
01/03/13 12:47 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Have any of you guys noticed this before.
I replaced my original rusted/pitted exterior door handles with
the chrome repro handles (chrome buttons).
Now when I go to use them the buttons rattle.
I noticed before connecting the linkage, the buttons didnt' rattle
because they are spring loaded..
But you have to engage the handle slightly to
connect the linkage from the door handle down to the latch.
Doing so, unloads the spring now just enough to cause
the buttons to rattle..
You guys experience this?
FWIW, I had to use the ball/spring mechanism from my old handles
because the new handles didn't come with the ball spring plate,
they came with the new style that uses plastic clip.
Mine are the old ball/metal clip type...
Any help/feedback appreciated - thanks!
Re: B- Body repro door handles - buttons rattle constantly [Re: OLD318] #1363762
01/04/13 12:39 PM
01/04/13 12:39 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Nobody has installed the repro exterior door handles?
Re: B- Body repro door handles - buttons rattle constantly [Re: OLD318] #1363763
01/04/13 12:58 PM
01/04/13 12:58 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
do the buttons have the rubber o-ring? And I have also seen a spring on the rod on the back of the button.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: B- Body repro door handles - buttons rattle constantly [Re: OLD318] #1363764
01/04/13 02:05 PM
01/04/13 02:05 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Are these chrysler boxed repops , which are the same as 70's pickups , or new aftermarket ?
Re: B- Body repro door handles - buttons rattle constantly [Re: JohnRR] #1363765
01/04/13 02:24 PM
01/04/13 02:24 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
That's a good question... I believe they are the chrysler boxed repops..
Re: B- Body repro door handles - buttons rattle constantly [Re: OLD318] #1363766
01/04/13 02:53 PM
01/04/13 02:53 PM
Roseville, Mich
rosevillemoparts Offline
Roseville, Mich
what year is your B-body?.
the genaric handles from mopar have the clip style for the rod,fit the AB and trucks but are wrong.
there are actually 4 different handle configurations for the 68-70
B Body and these do come with the plate and ball attached. difference between the handles are which direction the ball is pressed
to fit the rod
http://www.rosevillemoparts.com/advanced_search_result.php?keywords=mp52&search_in_description=1
Mopardave
If I don't reply to your PM
please email me at parts@mikeriehls.com
Re: B- Body repro door handles - buttons rattle constantly [Re: rosevillemoparts] #1363767
01/04/13 02:56 PM
01/04/13 02:56 PM
Roseville, Mich
Roseville, Mich
this is the common handle for most 68-70 B bodies
http://www.rosevillemoparts.com/product_...roducts_id/6350
Mopardave
Re: B- Body repro door handles - buttons rattle constantly [Re: rosevillemoparts] #1363768
01/04/13 05:05 PM
01/04/13 05:05 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Did you adjust the length by putting a Allen wrench into the hole right next to the latch on the door backside?
Re: B- Body repro door handles - buttons rattle constantly [Re: rosevillemoparts] #1363769
01/04/13 05:29 PM
01/04/13 05:29 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Its a 70 Coronet 2 door hardtop.
I bought them off of ebay around 2004.
They came with a plastic clip mechanism that didn't match
the ball/metal clip mechanism in the car.
So I had to remove (1 screw)the mechanisms from my old handle
and replace it on the new ones..
When I try to connect the ball/clip mechanism to the linkage on the latch,
I have to depress the button very very slightly...
This is what causes the rattling..
The button is no longer spring loaded.
The rubber o-rings are installed around the button
and are not damaged or broken....
It sounds like I have the wrong door handles..
Wouldn't surprise me...
conned by yet another web re-seller huh....
Re: B- Body repro door handles - buttons rattle constantly [Re: OLD318] #1363770
01/04/13 06:33 PM
01/04/13 06:33 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Did you read my answer???????
Re: B- Body repro door handles - buttons rattle constantly [Re: rosevillemoparts] #1363771
01/04/13 06:33 PM
01/04/13 06:33 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Did you grab the wrong picture? Those are 62-65.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: B- Body repro door handles - buttons rattle constantly [Re: RJS] #1363772
01/04/13 07:22 PM
01/04/13 07:22 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
No..I didn't see your answer until after I posted mine..
Thanks for the tip!!!!
Re: B- Body repro door handles - buttons rattle constantly [Re: OLD318] #1363773
01/04/13 09:47 PM
01/04/13 09:47 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
I tried to adjust via the allen screw..it does not good.
the button still rattles because the arm is a hair short.
Its the factory mechanism,clip,arm and latch.
But a repro door handle....
Does anyone else experience this?
Re: B- Body repro door handles - buttons rattle constantly [Re: OLD318] #1363774
01/04/13 10:17 PM
01/04/13 10:17 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I had in the past but was able to adjust out.
The only thing you can do is elongate one hole in the bar that goes from the handle to the latch to effectively make the distance between the holes longer on the bar.
OR:
Sell off those handles and get a current pair from BE+A.
Ron
Re: B- Body repro door handles - buttons rattle constantly [Re: RJS] #1363775
01/05/13 03:02 PM
01/05/13 03:02 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
TTT
Re: B- Body repro door handles - buttons rattle constantly [Re: 71TA] #1363776
01/08/13 01:27 PM
01/08/13 01:27 PM
Roseville, Mich
Roseville, Mich
maybe here is what the MFG shows as the pic. 4 different ways the ball is pressed
Mopardave
