Re: If you had to run a cast iron intake 440, what to use?
[Re: bgilbert]
#1363442
01/06/13 02:54 AM
01/06/13 02:54 AM
Posts: 43,293 Bend,OR USA
Cab_Burge
It's a stock class. Cast IRON intake and exhaust manifolds!
Ok just to be sure. Here is a pic of the intake manifold from my stock Dodge truck 75 440. Part # 3830733-2 and 05110 cast into it. I also have the same one on a 73 Dodge truck 440. When you all say 71 TQ manifold, are you not talking about just any TQ manifold? Is the 71 a taller/better manifold? Anyone have a pic? Thank you.
No Thermoquad carbs and intakes on 440 motors until 1973, as already pointed out I'm thinking a stock cast iron Thermoquad intake and a Carter 1000 CFM Competion series Thermoquad, if you can find one, might be a good combination If not a 1000 CFM then a 850 CFM Competion sereies And Max Wedge exhaust manifolds or 440-3 motor home center dumps
[Re: bgilbert]
#1363448
01/06/13 04:24 PM
01/06/13 04:24 PM
Cab_Burge
Maybe I'm confusing Quadrajet with Thermoquad .. Thanks again to all who reply. I never expected a rookie to get this much help. It certainly doesn't work that way on the diesel sites ..
Thermoquads are made by Carter, Quadrajets where made by Roochester.I don't think that any of the quadrajets ever exceeded 700 CFM, not so on the Thermoquads As far as a cast iron M.W. intake never was done as far as I know, I remember Richard Petty driving a single four barrel M.W. 727 automatic at Riversdie Raceway in probally 1962, he didn't finish The single four barrel intake for the M.W. was really low profile Have you heard of metal spray? Mopar had a lot of aluminum parts metal sprayed for the factory back racers to keep up with the competion, aluminum 4 speed cases, possibly some CH4B intakes with the Edlebrock #s ground off of them before spraying them,water pump housings, water pumps and other parts
